1550Z220
1550Z220
    HAMMONDMANUFACTURING
    BOX ALUM UNPAINTED 8.76"LX5.77"W
1550Z220 数据手册
210.00 [8.27] 222.50 [8.76] 77.00 [3.03] 3.00 [.12] (INSIDE DEPTH) A 134.00 [5.28] 138.49 [5.45] (INSIDE WIDTH) 146.50 [5.77] B B (AVERAGE WALL THICKNESS) A TOP VIEW 82.50 [3.25] SECTION A-A END VIEW 32.50 [1.28] 211.47 [8.33] 1.50 [.06] 192.37 [7.57] 4.50 [.18] 51.50 [2.03] 10.00 [.39] 214.49 [8.44] 135.47 [5.33] UL O 107.37 [4.23] (INSIDE LENGTH) C ® US LISTED FILE #E71073 NEMA 4, 4X SECTION B-B SIDE VIEW Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 216.15 [8.51] 197.05 [7.76] NOTE INSIDE LID C Purchased assembly includes box, lid, silicone gasket, and 4 cover screws. Box and lid are made from Diecast Aluminum Alloy. ACCEPTS M4 - 0.7 MACHINE SCREW Screws should not be torqued past 5-7.5 lbf.in ( 50 -75 cN.m) 116.00 [4.57] 140.15 [5.52] 210.00 [8.27] ACCEPTS #6 SELF TAPPING GROUND SCREW INSIDE BOX PART NUMBERS 111.22 [4.38] C 1550Z220 Enclosure Basic Enclosure Black Enclosure 12.00 [.47] ACCESSORIES Pre-Formed Silicone Gasket 1550Z220 1550Z220BK 1550Z220GASKET 8.01 4.36 [.32] [.17] SECTION C-C MOUNTING HOLE ® Dimensions: mm [inches] 1550Z220 www.hammondmfg.com
1550Z220
1. 物料型号:1550Z220
2. 器件简介: - 该器件为NEMA 4, 4X标准的防护等级箱体,适用于需要一定防护的场合。 - 箱体和盖子由压铸铝合金制成,包含预成型的硅胶垫圈和4个盖子螺丝。
3. 引脚分配: - 该箱体可接受M4-0.7的机器螺丝和#6自攻地螺丝。
4. 参数特性: - 箱体尺寸:内部尺寸为138.49毫米(宽)x 82.50毫米(高)x 77.00毫米(深)。 - 壁厚平均为3.00毫米。 - 盖子厚度为1.50毫米。
5. 功能详解: - 箱体设计用于保护内部元件免受尘埃、水和其他环境因素的影响。 - 可进行工厂修改,如铣削、钻孔、印刷等,具体可联系工厂获取报价。
6. 应用信息: - 适用于需要NEMA 4, 4X防护等级的场合,如工业控制、电气设备等。
7. 封装信息: - 购买的组装包括箱体、盖子、硅胶垫圈和4个盖子螺丝。 - 箱体和盖子由压铸铝合金制成。 - 螺丝不应超过5-7.5 lbf.in(50-75 cN.m)的扭矩。
1550Z220 价格&库存
很抱歉,暂时无法提供与“1550Z220”相匹配的价格&库存,您可以联系我们找货
1550Z220
    • 1+292.38931
    • 10+280.70498
    • 20+268.99983
    库存:1
