1551USB2BK
1551USB2BK
    HAMMONDMANUFACTURING
    Consumables
    Box Plastic, ABS Black Hand Held, Split Sides 1.969" L x 0.984" W (50.00mm x 25.00mm) X 0.610" (15.5...
1551USB2BK 数据手册
50.00 [1.97] 43.97 [1.73] 11.60 [.46] 15.50 [.61] A 18.97 [.75] B B 25.00 [.98] A 12.52 [.49] 5.50 [.22] 5.00 [.20] .50 [.02] Inlay Depth 6.55 [.26] 6.24 [.25] 5.00 [.20] 1.70 [.07] 21.41 [.84] 5.05 [.20] SECTION A-A 44.00 [1.73] 2.25 [.09] MAXIMUM P.C. BOARD SIZE (NOT SUPPLIED) 46.41 [1.83] 13.50 [.53] 3.50 [.14] SECTION B-B 16.00 18.10 20.50 [.63] [.71] [.81] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 2.00 33.00 [1.30] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. NOTE [.08] Purchased assembly includes box, lid, 2 cover screws. Enclosure molded from general purpose ABS Plastic. Other materials / colours available consult factory. 3.45 [.14] Recommended Torque : (35-43) Ozf.in / (25-30) cN.m Cover Screw accept #2x1/2" Self Tap screw 41.85 [1.65] 19.00 [.75] 14.31 [.56] 3.73 [.15] PART NUMBERS Mounting posts accept #2x3/16" Self Tap screw 1551USB2 Enclosure Black Enclosure - Ral 9011 - UL94 - HB 1551USB2BK Gray Enclosure - RAL 7035 - UL94 - HB 1551USB2GY Translucent Blue - UL94 - HB 1551USB2TBU Translucent Clear - UL94 - HB 1551USB2CLR Translucent Smoke - UL94 - HB 1551USB2TSK 1551USB2TRD Translucent Red - UL94 - HB ACCESSORIES P.C. Board Plastite Self Tapping Screw 1553WTS100 (Pkg 100) [#2 x 3/16" self-tapping (4.8mm)] 16.00 [.63] 1.50 [.06] R2.25 [R.09] 1.20 [.05] Black Cover Screws #2 X 1/2" Self-tapping 33.00 [1.30] 1551USB50BK (Pkg 50) 3.34 [.13] ® Dimensions: mm [inches] 1551USB2 www.hammondmfg.com
1551USB2BK
物料型号为HAMMOND 1551USB2,是一款由Hammond Manufacturing生产的塑料外壳。
器件简介包括多种颜色选择,如黑色、灰色、蓝色、透明、烟熏色和红色,以及可定制的工厂修改服务。
引脚分配参数特性未在文档中明确说明,但提到了最大PCB板尺寸、安装深度、螺丝规格等信息。
功能详解涉及外壳的一般用途,如保护内部组件,以及推荐的扭矩规格。
应用信息指出该外壳适用于多种电子设备,但具体应用未详细说明。
封装信息包括外壳的尺寸和材料,材料为ABS塑料,颜色和材料可根据需要定制。
配件包括自攻螺丝和盖子螺丝。
1551USB2BK 价格&库存
很抱歉,暂时无法提供与“1551USB2BK”相匹配的价格&库存,您可以联系我们找货
1551USB2BK
    • 1+72.78964
    库存:5
    1551USB2BK
    • 1+22.60249
    • 7+18.21854
    • 18+17.22436
    库存:5
