1591XXATBU
1591XXATBU
    HAMMONDMANUFACTURING
    BOX ABS TRN BLUE 3.97"L X 2.02"W
1591XXATBU 数据手册
100.90 [3.97] 21.00 [.83] INSIDE HEIGHT 87.50 [3.44] B 2.00 [.08] WALL THICKNESS 51.40 [2.02] A A B TOP VIEW 38.00 [1.50] 46.15 [1.82] INSIDE WIDTH 25.00 [.98] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 6.50 [.26] LID HEIGHT 4.50 [.18] 6.59 [.26] 4.34 [.17] 22.25 [.88] BOX HEIGHT 94.00 [3.70] 44.50 30.00 [1.75] [1.18] 95.65 [3.77] INSIDE LENGTH 80.00 [3.15] 25.00 [.98] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE SECTION A-A SIDE VIEW 65.00 [2.56] R4.00 [.16] 3.50 [.14] 98.43 [3.88] 48.93 [1.93] 5.00 [.20] 94.02 [3.70] 25.00 [.98] 44.52 [1.75] 25.00 [.98] INSIDE BOX M3-0.5 BRASS INSERTS INSTALLED BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS 1591XXA Enclosure 1591XXABK 1591XXAGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] Black Textured Enclosure Gray Textured Enclosure 5.00 [.20] 65.00 [2.56] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 65.00 [2.56] 4X 3.50 THRU  6.00 X 82° INSIDE LID Dimensions: mm [inches] 1591XXA www.hammondmfg.com ®
1591XXATBU 价格&库存
很抱歉,暂时无法提供与“1591XXATBU”相匹配的价格&库存,您可以联系我们找货
1591XXATBU
    • 1+60.27337
    • 4+49.35493
    • 8+41.36582
    库存:10
    1591XXATBU
      • 5+3.86141
      库存:83
      1591XXATBU
      • 1+63.483311+7.58947
      • 5+54.275595+6.48868
      • 10+50.7192310+6.06352
      • 25+46.3746625+5.54412
      • 50+43.3366750+5.18093
      • 100+40.50061100+4.84187
      • 250+37.03273250+4.42729
      • 500+35.94126500+4.29680
      库存:24
      1591XXATBU
      • 1+44.24673
      • 4+35.58664
      • 10+33.64620
      库存:10
