Top View of Assembly
SECTION A-A
(Side View Inside Assembly)
59.71
[2.351]
(Center Inlay Width)
18.50
[.728]
(Inner Box Height)
A
5.50
Detail View of PCB Boss
[.217]
(Top and Bottom
(Located on Bottom Cover)
5.00
[.197]
Assem Boss )
100.71
[3.965]
(Inlay Length)
117.24
[4.616]
5.00
[.197]
R353.57
[13.920]
A
P.C Board
Top Cover
Front Panel
51.61
[2.032]
(End Inlay Width)
End View of Assembly
B
1.16
[.046]
(PCB dist from inner wall)
SECTION B-B
(Inside of Bottom Cover)
Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.)
Contact Factory
mjm@hammondmfg.com for quotes
Solid models of this enclosure available in STEP or IGES.
(Part number and text placement/orientation on our products are subject to change,
we do not recommend using them as a locating reference for modification purposes)
NOTE
.50
[.02]
(Inlay Depth)
Front Panel
71.02
[2.796]
(Inner Box Width
at Center)
Enclosure molded from GP ABS Plastic.
62.86
[2.475]
(Inner Box Width 79.00
at End)
[3.110]
56.78
[2.236]
Purchased assembly includes Top, Bottom, front plastic panel, Battery
Door, battery spring clips (4 pcs), 9V adapter (1pcs) and 2 cover screws.
(P.C. Board not supplied)
Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m)
Bottom Cover
PART NUMBER
B
24.00
[.945]
P.C Board Aligned
on PCB Bosses
Black Enclosure/Grey Over‐mold
Grey Enclosure/Grey Over‐mold
Translucent Blue Enclosure/ Black Over‐mold
Red Enclosure/ Black Over‐mold
Yellow Enclosure/ Black Over‐mold
Black Enclosure/ Black Over‐mold
Maximum P.C. Board Size
10.90
[.429]
Front Panel
16.83
[.663]
(Viewing Area)
1553B Battery Enclosure
110.24
[4.340]
(Inner Box Length)
67.00
[2.638]
8.29
[.326]
58.11
[2.288]
62.63
[2.466]
(Viewing Area)
18.50
[.728]
78.18
[3.078]
40.00
[1.575]
1553BBKBAT
1553BGYBAT
1553BTBUBKBAT
1553BRDBKBAT
1553BYLBKBAT
1553BBKBKBAT
ACCESSORIES
Oval Head Cover Screws Self-Tapping (Pkg 100)
[#4 X 3/4" (19mm)]
22.74
[.895]
P.C. Board Self Tapping Screw
[#4 X 1/4" (6.4mm) Plated]
Belt or Pocket Clip
R3.16
[.125]
9V Battery Kit
AA Battery Clip Kit (4 positive and 4 Negative)
1593QS100 (Silver)
1593QS100BK (Black)
1593ATS50 (Pkg 50)
1593ATS100 (Pkg 100)
1599CLIP (Black)
1599CLIPGY (Grey)
BS61
1553HDR‐BKIT
(NOT SUPPLIED)
65.15
[2.565]
2.75
[.108]
3.20 x 4
R357.35
[14.069]
[.126]
56.96
[2.243]
60.78
[2.393]
Dimensions:
mm
[inches]
1553BBAT
www.hammondmfg.com
很抱歉,暂时无法提供与“1553BBKBKBAT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+134.33553
- 5+114.91253
- 10+107.41385
- 20+99.60668
- 50+91.78764
