1591XXEBK
1591XXEBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 7.62"L X 4.47"W
1591XXEBK 数据手册
193.41 [7.61] 177.50 [6.99] 57.00 [2.24] INSIDE HEIGHT B 2.00 [.08] WALL THICKNESS 113.41 [4.47] A 97.50 A 89.77 [3.53] INSIDE WIDTH [3.84] B TOP VIEW 6.50 [.26] LID HEIGHT SECTION B-B END VIEW 58.25 [2.29] BOX HEIGHT 185.65 [7.31] INSIDE LENGTH 4.50 [.18] 61.00 [2.40] M3-0.5 X10mm MACHINE SCREW 168.50 [6.63] 89.00 [3.50] 105.00 [4.13] SECTION A-A SIDE VIEW 185.00 [7.28] 8.00 [.31] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE 84.50 [3.33] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 22.50 [.89] R4.25 [.17] 66.25 [2.61] 3.50 [.14] 190.94 [7.52] 186.53 [7.34] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Purchased assembly includes box, lid, 6 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS 5.00 1591XXE Enclosure 1591XXEBK 1591XXEGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 5.00 [.20] 84.50 [3.33] 110.94 [4.37] 106.53 [4.19] 84.50 [3.33] 155.00 [6.10] 155.00 [6.10] INSIDE BOX [.20] Black Textured Enclosure Gray Textured Enclosure M3-0.5 BRASS INSERTS INSTALLED BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW 6X 3.50 THRU  6.00 X 82° INSIDE LID Dimensions: mm [inches] 1591XXE www.hammondmfg.com ®
1591XXEBK 价格&库存
很抱歉,暂时无法提供与“1591XXEBK”相匹配的价格&库存,您可以联系我们找货
