2
1
SECTION A-A
(Side View Inside Assembly)
Bottom View of Assembly
A
Front Face
Top Cover
n 8.37
n11.38
[.448]
(Bottom Boss n)
Detail View of Boss
[.329]
(Top Boss n)
(Located on Top and Bottom Cover)
3.75
[.148]
156.50
[6.161]
B
B
n 7.90
P.C. Board
[.311]
29.50
[1.161]
(Inner Box Height)
A
72.18
[2.842]
SECTION B-B
(Inside of Bottom Cover)
End View of Assembly
B
93.40
[3.677]
Top Cover
End Panel
.50
[.020]
(PCB dist from
end panel)
Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. )
Solid models of this enclosure available in STEP or IGES.
Contact Factory
mjm@hammondmfg.com
1.86
[.073]
(PCB dist from inner wall)
84.38
[3.322]
(Inner Box Width)
NOTE
Purchased Assembly includes top and bottom cover, front and end aluminum
panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4
rubber feet.
1598A Instrument Case
B
145.70
[5.736]
Inner Box Length
P.C. Board Aligned on Bosses
35.00
[1.378]
Front/Rear Panel
(Dashed Line Indicates Viewing Area)
Maximum P.C. Board Size
15.14
[.596]
81.90
[3.224]
(Viewing Area)
A
26.50
[1.043]
(Viewing Area)
29.00
[1.142]
FLAME RETARDANT ABS (UL94-VO)
Black Enclosure w ith Alum inum Panels
1598ABK
Gre y Enclosure w ith Alum inum Pa nels
1598AGY
Black EMI/RFI Shie lde d
1598RABK
NON-FLAME RETARDANT GPABS (UL94-HB)
1598ASGY
Gre y Enclosure w ith Black Plastic Pa ne ls
1598ASGYPBK
ACCESSORIES
Bla ck Plastic Pane ls
1598PLABK
Rubber Fee t (Pkg 24)
1421T2
For 1598 FR-ABS
1591MS100
Cover Screws (Pk g 100) [M3 - 0.5 x 10mm]
For 1598 GPABS
1591TS100
Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)]
For Both Mode ls
1598ATS100
PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)]
80.67
[3.176] 50.38
[1.984]
66.11
[2.603]
12.38
[.488]
P.C. Board
(Not Supplied)
10.55
[.415]
n3.51 X 4
[.138]
86.50
[3.406]
1.65
[.065]
2
12.31
[.485]
119.99
[4.724]
144.60
[5.693]
1598A
1
A
很抱歉,暂时无法提供与“1598ABK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+156.099201+20.29239
- 5+131.295365+17.06798
- 10+121.9776510+15.85670
- 25+110.7347125+14.39516
- 50+102.9669950+13.38538
- 100+95.77973100+12.45106
- 250+89.45548250+11.62893
