1553BTBUBKBAT
1553BTBUBKBAT
    HAMMONDMANUFACTURING
    BOX ABS TRN BLUE 4.62"L X 3.11"W
1553BTBUBKBAT 数据手册
Top View of Assembly SECTION A-A (Side View Inside Assembly) 59.71 [2.351] (Center Inlay Width) 18.50 [.728] (Inner Box Height) A  5.50 Detail View of PCB Boss [.217] (Top and Bottom (Located on Bottom Cover) 5.00 [.197] Assem Boss ) 100.71 [3.965] (Inlay Length) 117.24 [4.616]  5.00 [.197] R353.57 [13.920] A P.C Board Top Cover Front Panel 51.61 [2.032] (End Inlay Width) End View of Assembly B 1.16 [.046] (PCB dist from inner wall) SECTION B-B (Inside of Bottom Cover) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE .50 [.02] (Inlay Depth) Front Panel 71.02 [2.796] (Inner Box Width at Center) Enclosure molded from GP ABS Plastic.  62.86 [2.475] (Inner Box Width 79.00 at End) [3.110] 56.78 [2.236] Purchased assembly includes Top, Bottom, front plastic panel, Battery Door, battery spring clips (4 pcs), 9V adapter (1pcs) and 2 cover screws. (P.C. Board not supplied) Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) Bottom Cover PART NUMBER B 24.00 [.945] P.C Board Aligned on PCB Bosses Black Enclosure/Grey Over‐mold Grey Enclosure/Grey Over‐mold Translucent Blue Enclosure/ Black Over‐mold Red Enclosure/ Black Over‐mold Yellow Enclosure/ Black Over‐mold Black Enclosure/ Black Over‐mold Maximum P.C. Board Size 10.90 [.429] Front Panel 16.83 [.663] (Viewing Area) 1553B Battery Enclosure 110.24 [4.340] (Inner Box Length) 67.00 [2.638] 8.29 [.326] 58.11 [2.288] 62.63 [2.466] (Viewing Area) 18.50 [.728] 78.18 [3.078] 40.00 [1.575] 1553BBKBAT 1553BGYBAT 1553BTBUBKBAT 1553BRDBKBAT 1553BYLBKBAT 1553BBKBKBAT ACCESSORIES Oval Head Cover Screws Self-Tapping (Pkg 100) [#4 X 3/4" (19mm)] 22.74 [.895] P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] Belt or Pocket Clip R3.16 [.125] 9V Battery Kit AA Battery Clip Kit (4 positive and 4 Negative) 1593QS100 (Silver) 1593QS100BK (Black) 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) 1599CLIP (Black) 1599CLIPGY (Grey) BS61 1553HDR‐BKIT (NOT SUPPLIED) 65.15 [2.565] 2.75 [.108] 3.20 x 4 R357.35 [14.069] [.126] 56.96 [2.243] 60.78 [2.393] Dimensions: mm [inches] 1553BBAT www.hammondmfg.com ®
1553BTBUBKBAT 价格&库存
很抱歉,暂时无法提供与“1553BTBUBKBAT”相匹配的价格&库存,您可以联系我们找货
1553BTBUBKBAT
  • 1+108.17332
  • 2+88.28984
  • 4+83.48666
库存:20
1553BTBUBKBAT
    • 1+217.48123
    • 2+180.19874
    • 4+170.43427
    库存:20
