SECTION A-A
(Side View Inside Assembly)
Top View of Assembly
69.68
[2.743]
(Inlay Width)
A
19.50
[.768]
(Inner Box Height)
Top Cover
4.50
[.177]
(P.C. Board)
130.68
[5.145]
(Inlay Length)
147.24
[5.797]
6.00
[.236]
(Top and Bottom
5.00
Assem Boss )
Bottom Cover
A
Front Panel
[.197]
58.93
[2.320]
(Front Inlay Width)
Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.)
Contact Factory
mjm@hammondmfg.com for quotes
Solid models of this enclosure available in STEP or IGES.
89.00
[3.504]
End View of Assembly
B
(Part number and text placement/orientation on our products are subject to change,
we do not recommend using them as a locating reference for modification purposes)
SECTION B-B
(Inside of Bottom Cover)
.46
[.018]
(PCB dist from
end panel)
NOTE
Enclosure molded from GP ABS Plastic.
Purchased assembly includes Top, Bottom, front plastic panel, Battery
Door, battery spring clips (4 pcs), 9V adapter (1pcs) and 4 cover screws.
(P.C. Board not supplied)
Bottom Cover
Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m)
.50
[.02]
(Inlay Depth)
Front Panel
88.97
[3.503]
59.95
[2.360]
B
3.66
[.144]
(PCB dist from
inner wall)
68.93
[2.714]
(Inner Box Width
at End)
P.C. Board Aligned
on PCB Bosses
140.24
[5.521]
(Inner Box Length)
25.00
[.984]
80.98
[3.188]
(Inner Box Width
at Center)
68.94
[2.714]
(Viewing Area)
11.49
[.452]
30.14
[1.187]
Black Enclosure/Grey Over‐mold
Grey Enclosure/Grey Over‐mold
Translucent Blue Enclosure/ Black Over‐mold
Red Enclosure/ Black Over‐mold
Yellow Enclosure/ Black Over‐mold
Black Enclosure/ Black Over‐mold
45.89
[1.807]
Oval Head Cover Screws Self-Tapping (Pkg 100)
[#4 X 3/4" (19mm)]
3.20
P.C. Board Self Tapping Screw
[#4 X 1/4" (6.4mm) Plated]
[.126]
Belt or Pocket Clip
5.46
[.215]
R3.42
[.135]
19.77
[.778]
71.76
[2.83]
17.73
[.698]
67.32
[2.650]
46.04
[1.812]
(Viewing Area)
1553DBKBAT
1553DGYBAT
1553DTBUBKBAT
1553DRDBKBAT
1553DYLBKBAT
1553DBKBKBAT
ACCESSORIES
Maximum P.C. Board Size
Front Panel
PART NUMBER
1553D Battery Enclosure
(NOT SUPPLIED)
106.80
[4.205]
62.75
[2.470]
9V Battery Kit
AA Battery Clip Kit (4 positive and 4 Negative)
73.67
[2.900]
1593QS100 (Silver)
1593QS100BK (Black)
1593ATS50 (Pkg 50)
1593ATS100 (Pkg 100)
1599CLIP (Black)
1599CLIPGY (Grey)
BS61
1553HDR‐BKIT
2.50
[.098]
22.03
[.867]
10.28
[.405]
Dimensions:
mm
[inches]
1553DBAT
www.hammondmfg.com
很抱歉,暂时无法提供与“1553DGYBAT”相匹配的价格&库存,您可以联系我们找货
