1598BBK
1598BBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 5.29"L X 5.32"W
1598BBK 数据手册
2 Bottom View of Assembly Front Face 1 SECTION A-A (Side View Inside Assembly) Top Cover A Detail View of Boss n 8.46 n11.38 [.333] (Top Boss n) [.448] (Bottom Boss n) (Located on Top and Bottom Cover) 3.85 [.152] 134.30 [5.287] B B n 8.00 [.315] P.C. Board A 45.50 [1.791] (Inner Box Height) 113.30 [4.461] End View of Assembly B Top Cover 1.93 [.076] (PCB dist from inner wall) End Panel 135.20 [5.323] SECTION B-B (Inside of Bottom Cover) NOTE .50 [.020] (PCB dist from end panel) B Purchased Assembly includes top and bottom cover, front and end aluminum panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4 rubber feet. 22.82 [.898] 123.70 [4.870] (Viewing Area) 45.00 [1.772] 128.00 [5.039] P.C. Board Aligned on Bosses Maximum P.C. Board Size Front/Rear Panel (Dashed Line Indicates Viewing Area) 42.50 [1.673] (Viewing Area) 1598B Instrument Case 123.30 [4.854] (Inner Box Length) 51.00 [2.008] A Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Solid models of this enclosure available in STEP or IGES. Contact Factory mjm@hammondmfg.com 125.90 [4.957] (Inner Box Width) 122.04 [4.805] 76.40 [3.008] 54.98 [2.165] 12.33 [.486] P.C. Board (Not Supplied) 10.53 [.415] n3.51 X 6 [.138] FLAME RETARDANT ABS (UL94-VO) Black Enclosure w ith Alum inum Pane ls 1598BBK Grey Enclosure w ith Alum inum Pane ls 1598BGY Black EMI/RFI Shielde d 1598RBBK NON-FLAME RETARDANT GPABS (UL94-HB) Grey Enclosure w ith Alum inum Pane ls 1598BSGY Gre y Enclosure w ith Black Pla stic Panels 1598BSGYPBK ACCESSORIES Black Plastic Pa nels 1598PLBBK Rubber Feet (Pkg 24) 1421T2 For 1598 FR-ABS 1591MS100 Cover Screws (Pk g 100) [M3 - 0.5 x 10mm] For 1598 GPABS 1591TS100 Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)] For Both Mode ls 1598ATS100 PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)] 1.65 [.065] 29.00 [1.142] 64.30 [2.531] 1598B 122.30 [4.815] 2 1 A
1598BBK 价格&库存
很抱歉,暂时无法提供与“1598BBK”相匹配的价格&库存,您可以联系我们找货
1598BBK
  • 1+159.532261+20.00566
  • 5+136.418895+17.10719
  • 10+127.5007710+15.98884
  • 25+116.6095525+14.62307
  • 50+108.9907950+13.66766
  • 100+101.87091100+12.77481
  • 250+100.89623250+12.65259
库存:479
1598BBK
    • 1+127.90275
    库存:34
