1598BBBK
1598BBBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 7.05"L X 6.08"W
1598BBBK 数据手册
2 Bottom View of Assembly A 1 Front Face SECTION A-A (Side View Inside Assembly) Top Cover n11.69 n 8.74 [.460] (Bottom Boss n) 120.00 [4.724] 179.00 [7.047] Detail View of Boss [.344] (Top Boss n) (Located on Top and Bottom Cover) 5.25 [.207] 120.00 [4.724] n12.70 B [.315] 30.00 [1.181] (Inner Box Height) A 131.51 [5.178] B n 8.00 P.C. Board [.500] 18.50 [.728] SECTION B-B (Inside of Bottom Cover) End View of Assembly B End Panel 2.08 [.082] (PCB dist from inner wall) Top Cover 154.50 [6.083] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Solid models of this enclosure available in STEP or IGES. Contact Factory mjm@hammondmfg.com 145.21 [5.717] (Inner Box Width) .50 [.020] (PCB dist from end panel) NOTE Purchased Assembly includes top and bottom cover, front and end aluminum panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4 rubber feet. 1598BB Instrument Case B P.C. Board Aligned on Bosses 168.80 [6.646] (Inner Box Length) 35.00 [1.378] 23.33 [.918] Front/Rear Panel (Dashed Line Indicates Viewing Area) Maximum P.C. Board Size 77.66 [3.058] 12.47 [.491] 11.01 [.433] 142.50 [5.610] (Viewing Area) A 29.00 [1.142] 26.60 [1.047] (Viewing Area) 141.05 [5.553] 94.40 [3.717] 146.00 [5.748] 1.65 [.065] 2 11.58 [.456] n3.51 X 4 [.138] FLAME RETARDANT ABS (UL94-VO) 1598BBBK Bla ck Enclosure w ith Aluminum Pa ne ls 1598BBGY Grey Enclosure w ith Alum inum Panels 1598RBBBK Bla ck EMI/RFI Shielded NON-FLAME RETARDANT GPABS (UL94-HB) 1598BBSGY Grey Enclosure w ith Alum inum Panels 1598BBSGYPBK Gre y Enclosure w ith Bla ck Plastic Pa ne ls ACCESSORIES 1598PLBBBK Bla ck Plastic Pa ne ls 1421T2 Rubber Fee t (Pkg 24) For 1598 FR-ABS 1591MS100 Cover Screws (Pk g 100) [M3 - 0.5 x 10mm] For 1598 GPABS 1591TS100 Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)] For Both Models 1598ATS100 PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)] P.C. Board (Not Supplied) 1598BB 144.64 [5.694] 167.80 [6.606] 1 A
1598BBBK 价格&库存
很抱歉,暂时无法提供与“1598BBBK”相匹配的价格&库存,您可以联系我们找货
1598BBBK
  • 1+133.41167
库存:10
1598BBBK
  • 1+18.700381+2.34507
库存:2
1598BBBK
    • 4+218.477584+27.39751
    • 10+182.0905710+22.83451
    • 50+129.0626250+16.18470
    库存:5
