2
1
SECTION A-A
(Side View Inside Assembly)
Bottom View of Assembly
A
Top Cover
Front Face
n11.58
n 9.16
[.456]
(Bottom Boss n)
B
Detail View of Boss
(Located on Top and Bottom Cover)
[.361]
(Top Boss n)
3.20
[.126]
249.70
[9.831]
B
n 8.10
[.319]
P.C. Board
A
68.00
[2.677]
(Inner Box Height)
138.40
[5.449]
SECTION B-B
(Inside of Bottom Cover)
End View of Assembly
B
Top Cover
2.79
[.110]
(PCB dist from inner wall)
End Panel
159.00
[6.260]
.50
[.020]
(PCB dist from
end panel)
NOTE
Purchased Assembly includes top and bottom cover, front and end aluminum
panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4
rubber feet.
B
1598G Instrument Case
239.50
[9.429]
(Inner Box Length)
75.00
[2.953]
Front/Rear Panel
(Dashed Line Indicates Viewing Area)
145.90
[5.744]
(Viewing Area)
A
67.00
[2.638]
(Viewing Area)
Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. )
Solid models of this enclosure available in STEP or IGES.
Contact Factory
mjm@hammondmfg.com
149.14
[5.872]
(Inner Box Width)
69.50
[2.736]
P.C. Board Aligned on Bosses
Maximum P.C. Board Size
27.33
[1.076]
113.00
[4.449]
143.57
88.90
[5.652]
[3.500]
12.49
[.492]
P.C. Board
(Not Supplied)
8.83
[.348]
n3.51 X 4
FLAME RETARDANT ABS (UL94-VO)
1598GBK
Black Enclosure w ith Alum inum Pa nels
1598GGY
Gre y Enclosure w ith Aluminum Pa ne ls
1598RGBK
Bla ck EMI/RFI Shielded
NON-FLAME RETARDANT GPABS (UL94-HB)
1598GSGY
1598GSGYPBK
Grey Enclosure w ith Black Pla stic Pane ls
ACCESSORIES
1598PLGBK
Bla ck Pla stic Pa ne ls
1421T2
Rubber Fe e t (Pkg 24)
For 1598 FR-ABS
1591MS100
Cover Screws (Pk g 100) [M3 - 0.5 x 10mm]
For 1598 GPABS
1591TS100
Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)]
For Both Mode ls
1598ATS100
PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)]
[.138]
151.00
[5.945]
1.65
[.065]
42.40
[1.669]
1598G
153.70
[6.051]
238.50
[9.390]
2
1
A
很抱歉,暂时无法提供与“1598GBK”相匹配的价格&库存,您可以联系我们找货
