1553WDBK
1553WDBK
    HAMMONDMANUFACTURING
    BOXABSBLACK5.8"LX3.54"W
1553WDBK 数据手册
147.25 [5.80] 58.17 [2.29] 25.00 [.98] 69.65 [2.74] B 72.24 [2.84] B 129.71 [5.11] R1.00 [.04] USABLE FRONT PANEL 89.99 [3.54] 68.89 [2.71] 16.11 [.63] TOP VIEW 14.00 [.55] 56.72 [2.23] FRONT VIEW 140.63 [5.54] INSIDE LENGTH FOR TOP C FRONT PANEL 2.50 [.10] 139.62 [5.50] INSIDE LENGTH FOR BOTTOM 19.00 [.75] 89.0° Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) DETAIL C SCALE 1 : 1 SECTION B-B SIDE VIEW 69.00 [2.72] NOTE Enclosure made from UV Stabilized, FR ABS (UL 94‐V0) plastic. 69.00 [2.72] 58.00 [2.28] POSTS ACCEPT #2 X 3/16" SELF-TAPPING SCREW Purchased assembly includes Top, Bottom, Pre-Installed Silicone Gasket, and 4 Cover Screws. M3 Brass Inserts are Pre-Installed. 58.00 [2.28] Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) PART NUMBER 1553W D Liquid Resistant Enclosure 58.27 [2.29] 67.00 [2.64] 90.00 [3.54] 81.39 [3.20] 50.00 [1.97] 67.00 [2.64] INSIDE BOTTOM 140.53 [5.53] 90.00 [3.54] Black Enclosure/Grey Over‐mold Grey Enclosure/Grey Over‐mold 35.00 [1.38] 83.15 [3.27] 58.00 [2.28] 4.47 [.18] INSIDE TOP 1553WDBK 1553WDGY ACCESSORIES 67.00 [2.64] 50.00 [1.97] 67.00 [2.64] 35.00 [1.38] 58.00 [2.28] 59.90 [2.36] 35.00 [1.38] Silicone Pre‐formed Gaskets (Pkg 2) 1553WDGASKET Stainless Steel Cover screw (Pkg 100) [M3-0.5 X 18mm] SC1553WB100BK  (Black) P.C. Board Plastite Self Tapping Screw [#2 X 3/16" (6.4mm) Plated] 1553WTS100 (Pkg 100) 35.00 [1.38] ® Dimensions: mm [inches] 1553WD www.hammondmfg.com
1553WDBK 价格&库存
很抱歉,暂时无法提供与“1553WDBK”相匹配的价格&库存,您可以联系我们找货
1553WDBK
  • 1+194.734621+24.42010
  • 5+166.466695+20.87525
  • 10+155.6005110+19.51261
  • 25+142.3087725+17.84580
  • 50+133.0126150+16.68004
  • 100+126.22333100+15.82865
库存:336
