1457N1201BK
1457N1201BK
    HAMMONDMANUFACTURING
    BOX ALUM BLACK 5.08"L X 4.25"W
1457N1201BK 数据手册
8 7 6 5 4 3 2 1 129.00 mm [5.079 in] 50.11 +- 0.00 0.18 mm 114.00 mm [4.488 in] D [1.973 X +0.000 - 0.007 ] in D 6.00 mm [0.236 in] 108.00 mm 86.00 mm [4.252 in] [3.386 in] 96.00 +- 0.00 0.18 mm 101.00 +- 0.00 0.18 mm [ [3.976 ] 3.780 +- 0.000 0.007 in +0.000 - 0.007 in ] C C Y 4.25 mm [0.167 in] X [4.724 +0.02 - 0.02 in 2.00 +- 0.00 0.18 mm SECTION X-X 120.00 +- 0.54 0.50 mm [0.079 1.50 mm [0.059 in] ] +0.000 - 0.007 in PROTECTION TO IP 65 ] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. Inside Face to Face Dimension 2.50 mm [0.098 in] .75mm (.030") Deep Recess For Labels/Keypads etc. ASSEMBLY - VIEW FROM TOP B 58.61 mm [2.308 in] DETAIL Y 108.00 mm [4.252 in] 96.02 mm [3.780 in] 83.72 mm [3.296 in] 54.61 mm [2.150 in] R5.99 mm 4X [0.236 in] 58.61 mm [2.308 in] 45.14 mm [1.777 in] 54.33 mm [2.139 in] N O TE P u r c h a s e d a s s e m b ly in c lu d e s b o x , e n d p a n e ls , s t a in l e s s s t e e l # 6 T a p t ig h t s c re w s , s e lf a d h e s ive r u b b e r fe e t , g a s k e t s a n d O R in g s . B o x m a d e fro m E x t r u d e d A lu m in u m 6 0 6 3 . E n d p a n e ls m a d e fro m T y p e 3 8 0 D ie c a s t A lu m in u m w it h a b la c k p o w d e r p a in t fin is h . B W A TE R P R O O F 1 4 5 7 N 1 2 0 1 P ART NUM BERS C le a r a n o d iz e d b o x w it h b la c k p o w d e r 1457N 1201 p a in t e d e n d p a n e ls B la c k p o w d e r p a in t e d b o x a n d e n d 1457N 1201B K p a n e ls E M I / R F I S H I E L D E D (I P 5 4 ) C le a r a n o d iz e d b o x w it h b la c k p o w d e r 1457N 1201E p a in t e d e n d p a n e ls B la c k p o w d e r p a in t e d b o x a n d e n d 1457N 1201E B K p a n e ls A C C ES S O R IES S e e w e b s it e fo r a c c e s s o rie s . Fits 120mm (4.724") X 100mm (3.937") PCB Note: Aluminum extrusion has a tolerance of +/- .02" A A n5.00 mm x 0.60 mm 4X n3.60 mm x 8.00 mm v 7.00 mm x2.50 mm 4X 8 7 6 1457N1201 END PANEL - VIEW FROM OUTSIDE 5 4 3 2 1
1457N1201BK 价格&库存
很抱歉,暂时无法提供与“1457N1201BK”相匹配的价格&库存,您可以联系我们找货
1457N1201BK
  • 1+391.23651
  • 5+336.40835
  • 10+314.45810
  • 20+308.16965
库存:5
1457N1201BK
  • 1+335.139191+42.98520
  • 10+279.2826610+35.82100
  • 50+260.6931850+33.43670
库存:3
1457N1201BK
    • 1+335.65880
    • 5+327.27566
    • 10+319.09039
    • 15+311.56118
    • 20+304.14653
    库存:5
