1590Z150
1590Z150
    HAMMONDMANUFACTURING
    BOX ALUM UNPAINTED 8.69"LX4.74"W
1590Z150 数据手册
73.00 [2.87] 221.00 [8.70] 204.52 [8.05] (INSIDE DEPTH) A 120.50 [4.74] B 104.05 [4.10] B 107.12 [4.22] (INSIDE WIDTH) A TOP VIEW 80.50 [3.17] SECTION A-A END VIEW 20.50 [.81] 5.00 [.20] 206.30 [8.12] 2.00 [.08] 13.00 [.51] 183.04 [7.21] 5.60 [.22] UL O C 62.00 [2.44] (AVERAGE WALL THICKNESS) 183.30 [7.22] US LISTED Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 207.93 [8.19] 204.50 [8.05] (INSIDE LENGTH) NOTE Purchased assembly includes box, lid, silicone gasket, 4 cover screws and 4 ground screws with washers. Box and lid are made from Diecast Aluminum Alloy. INSIDE LID SECTION B-B SIDE VIEW C DRAWINGS AVALIBLE FOR STEEL INNER PANEL 211.14 [8.31] Recommended cover screw Torque 15-17 lbf.in ( 150 -170 cN.m) 1590Z150 188.14 [7.41] 1590Z150 Enclosure Basic Enclosure Black Enclosure 18.54 [.73] 10.21 [.40] 6.52 [.26] ® FILE #E65324 61.30 106.30 NEMA 4, 4X [2.41] [4.19] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) 104.00 [4.09] 82.00 [3.23] 204.50 [8.05] 16.00 [.63] SECTION C-C MOUNTING HOLE 26.00 [1.02] ACCEPTS M6 - 1 MACHINE SCREW C 111.14 [4.38] 66.14 [2.60] Grey Enclosure - RAL7001 Gloss 1590Z150 1590Z150BK 1590Z150GY ACCESSORIES Steel Inner Panel 1590Z150PL Pre-Formed Silicone Gasket Copper Ground Hardware (4 Pack) [M6 - 1.0 X 10mm / M6 Washer] 1590Z150G ACCEPTS M6 MACHINE GROUND SCREW INSIDE BOX SCGM6 ® Dimensions: mm [inches] 1590Z150 www.hammondmfg.com
1590Z150 价格&库存
很抱歉,暂时无法提供与“1590Z150”相匹配的价格&库存,您可以联系我们找货
1590Z150
  • 1+521.589271+67.60790
  • 10+434.6722610+56.34180
  • 50+405.7289850+52.59020
1590Z150
    • 1+462.16609
    库存:43
