1551HTBU
1551HTBU
    HAMMONDMANUFACTURING
    BOX ABS TRN BLUE 2.36"L X 1.38"W
1551HTBU 数据手册
48.50 [1.91] 60.00 [2.36] 16.00 [.63] B (INSIDE HEIGHT) 29.73 [1.17] 35.00 [1.38] A A (INSIDE WIDTH) 2.00 [.08] 23.50 [.93] 4.00 [.16] B 20.00 [.79] TOP VIEW 4.50 [.18] END VIEW SECTION B-B 12.00 [.47] 53.88 [2.12] 3.50 [.14] 17.00 [.67] 1.50 [.06] 5.00 [.20] 18.50 28.88 [.73] [1.14] 54.73 [2.15] (INSIDE LENGTH) SIDE VIEW SECTION A-A Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 43.50 [1.71] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) INSIDE LID 56.00 [2.20] 42.95 [1.69] 54.00 [2.13] 17.00 [.67] 17.95 [.71] ACCEPTS #2 SELF-TAPPING SCREW INSIDE BOX 4.00 [.16] 31.00 [1.22] NOTE Purchased assembly includes box, lid, 2 cover screws. Enclosure molded from general purpose ABS Plastic. Other materials / colours available consult factory. Recommended Torque : (35-43) Ozf.in / (25-30) cN.m 6.25 [.25] PART NUMBERS R3.00 [.12] 2.75 [.11] 6.25 [.25] 23.50 [.93] 29.00 [1.14] 20.00 [.79] MAXIMUM P.C. BOARD SIZE 1551H Enclosure Black Enclosure - Ral 9011 - UL94 - HB 1551HBK 1551HGY Gray Enclosure - RAL 7035 - UL94 - HB 1551HTBU Tranlucent Blue - UL94 - HB ACCESSORIES 1591TS100BK (Pkg 100) Black Cover Screws #4 X 1/2" Self-tapping 1591TS100 (Pkg 100) Plated Cover Screws #4 X 1/2" Self-tapping 1551ATS50 (Pkg 50) P.C. Board Screws [#2 x 3/16" self-tapping (4.8mm)] 1551ATS100 (Pkg 100) 2.50 ® [.10] Dimensions: mm [inches] 1551H www.hammondmfg.com
1551HTBU
1. 物料型号:1551H Enclosure 2. 器件简介:文档提供了1551H型号的详细尺寸和视图,包括内部尺寸、端视图和顶视图。 3. 引脚分配:文档中未明确提及引脚分配。 4. 参数特性:列出了不同材料和颜色的1551H Enclosure型号,包括黑色(RAL 9011)、灰色(RAL 7035)和蓝色半透明(UL94-HB)。 5. 功能详解:文档提到了可以工厂修改(铣削、钻孔、打印等),并提供了联系方式mjm@hammondmfg.com以获取报价。还提到了产品可以提供STEP或IGES格式的实体模型。 6. 应用信息:文档中提到了产品可以接受#2自攻螺丝,并给出了PCB板的最大尺寸。 7. 封装信息:提供了一些配件的信息,如黑色盖子螺丝、镀层盖子螺丝和PCB板螺丝。
1551HTBU 价格&库存
很抱歉,暂时无法提供与“1551HTBU”相匹配的价格&库存,您可以联系我们找货
1551HTBU
  • 1+20.24282
  • 8+16.49371
  • 20+15.58338
库存:9
1551HTBU
  • 1+32.669901+3.90571
  • 5+27.932245+3.33932
  • 10+26.1016910+3.12048
  • 25+23.8650025+2.85308
  • 50+22.3022450+2.66625
  • 100+20.84215100+2.49169
  • 250+19.05802250+2.27840
  • 500+17.81024500+2.12923
  • 1000+17.037091000+2.03680
库存:166
1551HTBU
    • 1+64.97807
    • 7+33.82055
    库存:9
