1591XXCTBU
1591XXCTBU
    HAMMONDMANUFACTURING
    BOX ABS TRN BLUE 4.78"L X 2.64"W
1591XXCTBU 数据手册
121.44 [4.78] 36.00 [1.42] INSIDE HEIGHT 107.00 [4.21] B 2.00 [.08] WALL THICKNESS 66.94 [2.64] A A B TOP VIEW 6.50 [.26] LID HEIGHT 6.10 [.24] 4.34 [.17] 52.50 [2.07] 40.00 [1.57] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 37.25 [1.47] BOX HEIGHT 114.50 [4.51] 44.50 [1.75] 60.50 [2.38] 115.15 [4.53] INSIDE LENGTH 4.50 [.18] 60.65 [2.39] INSIDE WIDTH 99.00 [3.90] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE 39.50 [1.56] R3.50 [.14] SECTION A-A SIDE VIEW 84.50 [3.33] 3.50 [.14] 118.98 [4.68] 114.57 [4.51] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS 64.48 [2.54] 5.00 [.20] 39.50 [1.56] 39.50 [1.56] 60.07 [2.36] 5.00 [.20] 84.50 [3.33] INSIDE BOX M3-0.5 BRASS INSERTS INSTALLED 84.50 [3.33] 4X 3.50 THRU  6.00 X 82° INSIDE LID BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW 1591XXC Enclosure 1591XXCBK 1591XXCGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] Black Textured Enclosure Gray Textured Enclosure Dimensions: mm [inches] 1591XXC www.hammondmfg.com ®
1591XXCTBU 价格&库存
很抱歉,暂时无法提供与“1591XXCTBU”相匹配的价格&库存,您可以联系我们找货
