1591XXTBK
1591XXTBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 4.85"L X 3.28"W
1591XXTBK 数据手册
123.27 [4.85] 107.50 [4.23] 55.00 [2.17] INSIDE HEIGHT B 2.00 [.08] WALL THICKNESS 67.50 [2.66] A A B TOP VIEW 6.50 [.26] LID HEIGHT 6.11 [.24] 83.27 [3.28] 59.00 [2.32] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 4.34 [.17] 115.00 [4.53] 56.25 [2.21] BOX HEIGHT 4.50 [.18] 75.65 [2.98] INSIDE WIDTH 59.00 [2.32] 75.00 [2.95] 115.65 [4.55] INSIDE LENGTH 99.00 [3.90] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE SECTION A-A SIDE VIEW 54.50 [2.15] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. R4.00 [.16] 85.00 [3.35] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE 3.50 Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m [.14] 116.39 [4.58] 120.80 [4.76] 5.00 80.80 [3.18] PART NUMBERS 5.00 [.20] 54.50 [2.15] 76.39 [3.01] 54.50 [2.15] 85.00 [3.35] 85.00 [3.35] INSIDE BOX M3-0.5 BRASS INSERTS INSTALLED BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW 1591XXT Enclosure 1591XXTBK 1591XXTGY ACCESSORIES Black Cover Screws [M3-0.5 X10mm] 1591MS100BK (Pkg 100) Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] Black Textured Enclosure Gray Textured Enclosure [.20] 4X 3.50 THRU  6.00 X 82° INSIDE LID Dimensions: mm [inches] 1591XXT www.hammondmfg.com ®
1591XXTBK 价格&库存
很抱歉,暂时无法提供与“1591XXTBK”相匹配的价格&库存,您可以联系我们找货
1591XXTBK
    • 1+150.01767
    库存:1
    1591XXTBK
    • 1+115.288431+13.78280
    • 5+98.526185+11.77886
    • 10+92.0751710+11.00764
    • 25+84.1941625+10.06546
    • 50+78.6805150+9.40630
    • 100+73.52925100+8.79047
    • 250+70.24882250+8.39829
    库存:46
