2
Bottom View of Assembly
Front Face
1
SECTION A-A
(Side View Inside Assembly)
Top Cover
A
Detail View of Boss
n 8.46
n11.38
[.333]
(Top Boss n)
[.448]
(Bottom Boss n)
(Located on Top and Bottom Cover)
3.85
[.152]
134.30
[5.287]
B
B
n 8.00
[.315]
P.C. Board
A
45.50
[1.791]
(Inner Box Height)
113.30
[4.461]
End View of Assembly
B
Top Cover
1.93
[.076]
(PCB dist from inner wall)
End Panel
135.20
[5.323]
SECTION B-B
(Inside of Bottom Cover)
NOTE
.50
[.020]
(PCB dist from
end panel)
B
Purchased Assembly includes top and bottom cover, front and end aluminum
panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4
rubber feet.
22.82
[.898]
123.70
[4.870]
(Viewing Area)
45.00
[1.772]
128.00
[5.039]
P.C. Board Aligned on Bosses
Maximum P.C. Board Size
Front/Rear Panel
(Dashed Line Indicates Viewing Area)
42.50
[1.673]
(Viewing Area)
1598B Instrument Case
123.30
[4.854]
(Inner Box Length)
51.00
[2.008]
A
Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. )
Solid models of this enclosure available in STEP or IGES.
Contact Factory
mjm@hammondmfg.com
125.90
[4.957]
(Inner Box Width)
122.04
[4.805]
76.40
[3.008]
54.98
[2.165]
12.33
[.486]
P.C. Board
(Not Supplied)
10.53
[.415]
n3.51 X 6
[.138]
FLAME RETARDANT ABS (UL94-VO)
Black Enclosure w ith Alum inum Pane ls
1598BBK
Grey Enclosure w ith Alum inum Pane ls
1598BGY
Black EMI/RFI Shielde d
1598RBBK
NON-FLAME RETARDANT GPABS (UL94-HB)
1598BSGY
Gre y Enclosure w ith Black Pla stic Panels
1598BSGYPBK
ACCESSORIES
Black Plastic Pa nels
1598PLBBK
Rubber Feet (Pkg 24)
1421T2
For 1598 FR-ABS
1591MS100
Cover Screws (Pk g 100) [M3 - 0.5 x 10mm]
For 1598 GPABS
1591TS100
Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)]
For Both Mode ls
1598ATS100
PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)]
1.65
[.065]
29.00
[1.142]
64.30
[2.531]
1598B
122.30
[4.815]
2
1
A
很抱歉,暂时无法提供与“1598BGY”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+156.369521+18.69407
- 5+133.645795+15.97743
- 10+124.8985610+14.93169
- 25+114.2089725+13.65375
- 50+106.7316150+12.75983
- 100+99.74305100+11.92434
- 250+98.95514250+11.83014
- 国内价格
- 1+125.76900
- 2+101.38179
- 4+95.84796
