1598ESGY
1598ESGY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 6.31"L X 6.25"W
1598ESGY 数据手册
2 1 SECTION A-A (Side View Inside Assembly) Bottom View of Assembly Front Face A n11.68 n 9.01 [.460] (Top Bossn ) [.355] (Bottom Boss n) Detail View of Boss (Located on Top and Bottom Cover) 3.10 [.122] 160.35 [6.313] n 8.40 B B [.331] Front Face A 78.00 [3.071] (Inner Box Height) 137.85 [5.427] End View of Assembly B SECTION B-B (Inside of Bottom Cover) Top Cover 2.76 [.109] (PCB dist from inner wall) End Panel 158.65 [6.246] .50 [.020] (PCB dist from end panel) B 149.10 [5.870] (Inner Box Width) NOTE Purchased Assembly includes top and bottom cover, front and end aluminum panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4 rubber feet. 149.44 [5.883] (Inner Box Length) 85.20 [3.354] Front/Rear Panel (Dashed Line Indicates Viewing Area) 145.55 [5.730] (Viewing Area) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Solid models of this enclosure available in STEP or IGES. Contact Factory mjm@hammondmfg.com P.C. Board Aligned on Bosses Maximum P.C. Board Size 27.38 [1.078] 67.92 [2.674] 12.60 [.496] 9.17 [.361] A 77.00 [3.031] (Viewing Area) 79.50 [3.130] 150.00 [5.906] 1.65 [.065] 143.58 [5.653] 88.83 [3.497] 29.75 [1.171] P.C. Board (Not Supplied) n3.51 X 4 1598E Instrument Case FLAME RETARDANT ABS (UL94-VO) Black Enclosure w ith Alum inum Pa nels 1598EBK Gre y Enclosure w ith Alum inum Pa ne ls 1598EGY Black EMI/RFI Shielde d 1598REBK NON-FLAME RETARDANT GPABS (UL94-HB) Gre y Enclosure w ith Alum inum Pa ne ls 1598ESGY Grey Enclosure w ith Black Plastic Panels 1598ESGYPBK ACCESSORIES Bla ck Pla stic Pa ne ls 1598PLEBK Rubber Fe et (Pkg 24) 1421T2 For 1598 FR-ABS 1591MS100 Cover Screws (Pk g 100) [M3 - 0.5 x 10mm] For 1598 GPABS 1591TS100 Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)] For Both Mode ls 1598ATS100 PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)] [.138] 88.95 [3.502] 1598E 148.44 [5.844] 2 1 A
1598ESGY 价格&库存
很抱歉,暂时无法提供与“1598ESGY”相匹配的价格&库存,您可以联系我们找货
