1553TGY
1553TGY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 8.27"L X 3.94"W
1553TGY 数据手册
Rear View of Assembly Top View of Assembly 100.0 [3.94] SECTION A-A (Side View of Assembly) 83.24 [3.28] (Inlay Width) 56.00 [2.2] 32.00 [1.26] A (Inlay Width) 63.95 [2.52] (Inlay Length) 42.00 [1.65] (Inlay Length) Removable Panel 1.50 [.06] (Top Inlay Depth) .50 [.02] (Rear Inlay Depth) 6.30 [.25] 210.0 [8.27] 124.24 [4.89] (Inlay Length) 5.00 [.2] 2.75 [.11] (Wall Thickness) A 85.9 [3.38] 69.05 [2.72] (Inlay Width) 25.00 [.98] (Inner Box Height) Removable Panel Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Enclosure made from FR ABS (UL 94‐V0) plastic. 55.00 mm [2.17 in] 82.00 mm [3.23 in] Bottom End View of Assembly 20.95 mm [.82 in] Purchased assembly includes Top, Bottom, front plastic panel and 6Cover Screws. M3 Brass Inserts are Pre-Installed. Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) 62.70 [2.47] (Viewing Area) 24.25 [.95] (Viewing Area) 40.00 mm [1.57 in] 9.0 mm [.35 in] 9.00 mm [.35 in] PART NUMBER 1553T Regular Enclosure Black Enclosure/Grey Over‐mold Grey Enclosure/Grey Over‐mold 28.00 mm [1.10 in] 1553TBK 1553TGY ACCESSORIES Front/Rear Panel 50.00 mm [1.97 in] 55.00 mm [2.17 in] 65.28 [2.57] 12 PCB Posts on Bottom PCB post accepts #4 X 1/4" self tap screw 56.00 mm [2.20 in] 27.50 [1.08] 10 PCB Posts on Top Drawings available for maximum P.C Board size. Cover screw (Pkg 100) [M3-0.5 X 18mm] P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] Belt or Pocket Clip 1594MS100 (silver) 1594MS100BK (Black) 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) 1599CLIP (Black) 1599CLIPGY (Grey) M3 Insert for Cover Screws 2.75 [.11] Inside View of Top Inside View of Bottom Dimensions: mm [inches] 1553T www.hammondmfg.com ®
1553TGY 价格&库存
很抱歉,暂时无法提供与“1553TGY”相匹配的价格&库存,您可以联系我们找货
