1598FBK
1598FBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 9.83"L X 6.27"W
1598FBK 数据手册
2 1 SECTION A-A (Side View Inside Assembly) Bottom View of Assembly A Top Cover Front Face n10.96 n 8.34 [.432] (Bottom Boss n) [.328] (Top Boss n) Detail View of Boss (Located on Top and Bottom Cover) 3.10 [.122] 249.70 [9.831] B B n 8.40 P.C. Board [.331] A 33.70 [1.327] (Inner Box Height) 138.96 [5.471] SECTION B-B (Inside of Bottom Cover) End View of Assembly B Top Cover 2.75 [.108] (PCB dist from inner wall) End Panel 159.25 [6.270] 150.21 [5.914] (Inner Box Width) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Solid models of this enclosure available in STEP or IGES. Contact Factory mjm@hammondmfg.com .50 [.020] (PCB dist from end panel) B 239.35 [9.423] (Inner Box Length) 40.90 [1.610] Front/Rear Panel (Dashed Line Indicates Viewing Area) 146.15 [5.754] (Viewing Area) A 35.00 [1.378] 32.70 [1.287] (Viewing Area) NOTE Purchased Assembly includes top and bottom cover, front and end aluminum panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4 rubber feet. P.C. Board Aligned on Bosses Maximum P.C. Board Size 28.11 [1.107] 144.71 [5.697] 88.50 [3.484] 113.22 [4.457] 11.92 [.469] 8.83 [.348] P.C. Board (Not Supplied) n3.51 X 4 1598F Instrument Case FLAME RETARDANT ABS (UL94-VO) 1598FBK Black Enclosure w ith Aluminum Pane ls 1598FGY Grey Enclosure w ith Alum inum Pane ls 1598RFBK Bla ck EMI/RFI Shie lde d NON-FLAME RETARDANT GPABS (UL94-HB) 1598FSGY Grey Enclosure w ith Alum inum Pane ls 1598FSGYPBK Gre y Enclosure w ith Bla ck Plastic Pa nels ACCESSORIES 1598PLFBK Bla ck Plastic Pa nels 1421T2 Rubber Fee t (Pkg 24) For 1598 FR-ABS 1591MS100 Cover Screws (Pk g 100) [M3 - 0.5 x 10mm] For 1598 GPABS 1591TS100 Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)] For Both Models 1598ATS100 PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)] [.138] 151.38 [5.960] 1.65 [.065] 42.48 [1.672] 1598F 153.40 [6.039] 238.35 [9.384] 2 1 A
1598FBK 价格&库存
很抱歉,暂时无法提供与“1598FBK”相匹配的价格&库存,您可以联系我们找货
1598FBK
    • 1+192.12488
    库存:2
