1555TGY
1555TGY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 7.09"L X 4.72"W
1555TGY 数据手册
1555 Watertight Plastic - Styled Lid Key Features • Ideally suited for mounting printed circuit boards or DIN rail mounted components (see photo features below for details). • “Styled” lid version has three main advantages over our flat lid (1554 series) - also see photo features below: »» Smooth recessed surface on lid for a membrane keypad or label »» Standoffs molded in the interior of the lid (except for size “B”). Designed for #6 self tapping screws »» More modern “styled” look vs. our traditonal flat lid (1554 series) • ABS Versions are molded from general purpose material which carries a flammability rating of UL94-HB. For indoor use. • Polycarbonate versions are UV stabilized for outdoor use. Gray polycarb carries a UL94-5VA rating. • Polycarbonate versions are UL 508 listed (File # E65324). • Enclosure color is a light gray (RAL 7035). • Gasketed lid with two piece “tongue & groove” construction provides protection against access of oil, dust and water. • Gasket is one piece made from high temperature, U.L. listed silicone. • Designed to meet IP 66 & NEMA 4, 4X, 12 & 13 ratings. • Lid is secured with included M4 stainless steel machine screws which are threaded into integral stainless steel bushings for repetitive assembly & disassembly. All hardware is stainless steel to avoid corrosion caused by dissimilar metals. • Lid screws are self captivating (lid holes are threaded with the first installation of lid screws). • Internal features are maximized for mounting options and vary with size: »» Internal DIN rail mounting tabs molded into most models, except sizes “C” and “D”. »» Threaded (M3) integral brass inserts and/or standoffs (for #6 self tapping screws) for P.C. board or inner panel mounting in all but the smallest size (“B”). »» Vertical P.C. card guides (for 1.5 mm thick P.C. boards) are molded in all but the smallest size (“B”). www.hammondmfg.com Accessories Inner Panels Foot Kit USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 36 1555 Watertight Plastic - Styled Lid PC board mounting bosses molded into the lid as well as the box. Shown here with galvanized steel inner panel installed Feet kit can be installed and locked in place either vertically or horizontally Wall or shelf-mount through holes in the back og the enclosure (outside the gasket perimeter). L D www.hammondmfg.com D W USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 37 1555 Watertight Plastic - Styled Lid Lid Screws Units Length (L) Width (W) Total Height (D+D) Inner Panel Foot Kit Replacement Gasket 1555B2GY 4 in mm 2.6 65 2.6 65 1.6 40 1554BPL 1554FT 1554BGASKET 1555EGY 1555E2GY 4 in mm 3.5 90 3.5 90 2.4 60 1554EPL 1554FT 1554EGASKET 1555EEGY 1555EE2GY 4 in mm 3.5 90 3.5 90 90.5 3.56 1554EPL 1554FT 1554EGASKET 1555CGY 1555C2GY 4 in mm 4.7 120 2.6 65 1.6 40 1554CPL 1554FT 1554CGASKET 1555DGY 1555D2GY 4 in mm 4.7 120 2.6 65 2.4 60 1554CPL 1554FT 1554CGASKET 1555FGY 1555F2GY 4 in mm 4.7 120 3.5 90 2.4 60 1554FPL 1554FT 1554FGASKET 1555GGY 1555G2GY 4 in mm 4.7 120 3.5 90 3.15 80 1554FPL 1554FT 1554FGASKET 1555NGY 1555N2GY 4 in mm 4.7 120 4.7 120 2.4 60 1554NPL 1554FT 1554NGASKET 1555PGY 1555P2GY 4 in mm 4.7 120 4.7 120 3.15 80 1554NPL 1554FT 1554NGASKET 1555JGY 1555J2GY 4 in mm 6.3 160 3.5 90 2.4 60 1554JPL 1554FT 1554JGASKET 1554KGY 1555K2GY 4 in mm 6.3 160 3.5 90 3.5 90 1554JPL 1554FT 1554JGASKET 1555RGY 1555R2GY 4 in mm 6.3 160 6.3 160 2.4 60 1554RPL 1554FT 1554RGASKET 1555SGY 1555S2GY 4 in mm 6.3 160 6.3 160 3.5 90 1554RPL 1554FT 1554RGASKET 1555HGY 1555H2GY 4 in mm 7.1 180 4.7 120 2.4 60 1554HPL 1554FT 1554HGASKET 1555TGY 1555T2GY 4 in mm 7.1 180 4.7 120 3.5 90 1554HPL 1554FT 1554HGASKET 1555UGY 1555U2GY 4 in mm 7.9 200 4.7 120 3.5 90 1554UPL 1554FT 1554UGASKET 1555VGY 1555V2GY 4 in mm 9.4 240 6.3 160 3.5 90 1554VPL 1554FT 1554VGASKET 1555VAGY 1555VA2GY 6 in mm 9.4 240 6.3 160 3.5 90 1554VAPL 1554FT 1554VAGASKET 1555VBGY 1555VB2GY 6 in mm 9.4 240 6.3 160 4.7 120 1554VAPL 1554FT 1554VAGASKET 1555XGY 1555X2GY 6 in mm 11.81 300 7.87 200 3.54 90 1554XPL 1554FT 1554XGASKET 1555XAGY 1555XA2GY 6 in mm 11.81 300 7.87 200 4.72 120 1554XPL 1554FT 1554XGASKET 1555YGY 1555Y2GY 6 in mm 11.81 300 9.45 240 3.74 95 1554YPL 1554FT 1554YGASKET 1555YAGY 1555YA2GY 6 in mm 11.81 300 9.45 240 4.72 120 1554YPL 1554FT 1554YGASKET ABS Plastic With Gray Lid Polycarbonate With Gray Lid 1555BGY www.hammondmfg.com USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 38
1555TGY
物料型号:1555系列,包括不同尺寸和材质的型号,如1555BGY、1555EGY等。
器件简介:这是一种适合安装印刷电路板或导轨安装组件的防水塑料盒,具有带造型的盖子,与平盖版本相比,具有更现代的外观和一些额外的优势。
引脚分配:文档中没有明确提到引脚分配,但提到了内部DIN导轨安装片、M3螺纹黄铜嵌件和/或支架(用于#6自攻螺丝)以及垂直PC卡导轨。
参数特性: - ABS版本:通用材料,UL94-HB阻燃等级,室内使用。 - 聚碳酸酯版本:紫外线稳定,适合户外使用,灰色聚碳酸酯具有UL94-5VA等级。 - 聚碳酸酯版本:UL 508认证。 - 外壳颜色:浅灰色(RAL 7035)。 - 带密封圈的盖子,采用两片式“舌槽”结构,提供油、尘、水的防护。 - 密封圈由高温、UL认证的硅胶制成。 - 符合IP 66和NEMA 4, 4X, 12 & 13等级。
功能详解:文档中没有提供详细的功能解释,但提到了盖子通过包括的M4不锈钢机螺丝固定,这些螺丝螺纹进入整体不锈钢衬套,以实现重复组装和拆卸。
应用信息:适用于需要防水、防尘和防油的应用场景。
封装信息:提供了不同尺寸和材质的封装选项,以及配件如内面板、脚套件等。
1555TGY 价格&库存
很抱歉,暂时无法提供与“1555TGY”相匹配的价格&库存,您可以联系我们找货
1555TGY
    • 1+316.90122
    • 2+300.03533
    库存:4
    1555TGY
    • 1+154.92345
    • 3+146.47896
    库存:4
