1590DE
1590DE
    HAMMONDMANUFACTURING
    BOX ALUM UNPAINTED 7.88"LX4.73"W
1590DE 数据手册
200.20 [7.882] 59.80 [2.354] INSIDE HEIGHT 190.00 [7.480] A 110.00 [4.331] B B 112.69 [4.437] INSIDE WIDTH 120.20 [4.732] 5.60 [.220] SECTION A-A END VIEW 64.30 [2.531] A TOP VIEW 2.25 [.089] 6X M3.5 X 0.6 12.6 1.50 [.059] 181.00 [7.126] 60.20 [2.370] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 115.70 [4.555] 97.99 [3.858] 2.25 [.089] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 101.00 [3.976] Recommended Torque: 50-55 cN.m [71-78 ozf.in] Recommended Torque with Gasket : 25-30 cN.m [36-43 ozf.in] 192.69 [7.586] INSIDE LENGTH PART NUMBERS SECTION B-B SIDE VIEW 1590DE Enclosure 1590DE Natural Finish Enclosure 1590DEBK Black Textured Enclosure 1590DE Liquid Resistant Enclosure (Silicone Gasket) 1590W DE Natural Finish Enclosure 1590W DEBK Black Textured Enclosure ACCESSORIES 181.00 [7.126] INSIDE BOX 6X 4.38 [.172] 4.27 [.168] Liquid Resistant Cover Screws 1.50 [.059] 191.67 [7.546] 176.47 [6.948] INSIDE LID Stainless Steel Cover Screw s (Pkg 100) [M3.5 x 12mm, W ith O-Ring] 1550W MS100 Black Stainless Steel Cover Screw s (Pkg 100) [M3.5 x 12mm, W ith O-Ring] 1550W MS100BK Standard Cover Screws 111.27 [4.381] 95.93 [3.777] NOTE Purchased assembly includes box, lid and 6 cover screws. Box and lid are made from Diecast Aluminum Alloy. Silicone Gasket supplied with liquid resistant enclosure. Plated Cover Screw s (Pkg 100) [M3.5 x 12mm] Black Cover Screw s (Pkg 100) [M3.5 x 12mm] 97.47 [3.837] 4.10 [.161] Dimensions: mm [inches] 1550MS100 1550MS100BK 1590DE www.hammondmfg.com ®
1590DE
物料型号:1590DE Enclosure(1590DE 型号外壳)
器件简介:这是一个由压铸铝合金制成的外壳,包括盒子、盖子和6个盖子螺丝。液体抗性外壳还附带了硅胶垫圈。
引脚分配:文档中没有提供具体的引脚分配信息。
参数特性:外壳的内部尺寸为长192.69mm x 宽120.20mm x 高59.80mm,盖子的内部尺寸为长181.00mm x 宽110.00mm x 高2.25mm。螺丝孔的直径为M3.5,深度为0.6mm。
功能详解:外壳可以进行工厂修改(铣削、钻孔、打印等)。联系工厂获取报价和STEP或IGES格式的实体模型。
应用信息:适用于需要保护内部电子元件免受液体侵入的应用场景。
封装信息:外壳有自然色和黑色纹理两种表面处理方式。液体抗性外壳型号为1590WDE,自然色和黑色纹理型号分别为1590WDE和1590WDEBK。
配件信息:包括液体抗性盖螺丝、不锈钢盖螺丝(带O型圈)、标准盖螺丝和镀层盖螺丝等。
1590DE 价格&库存
很抱歉,暂时无法提供与“1590DE”相匹配的价格&库存,您可以联系我们找货
1590DE
    • 1+201.44527
    库存:47
