1554TGY
1554TGY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 7.09"L X 4.72"W
1554TGY 数据手册
167.00 [6.57] 180.00 [7.09] 84.50 [3.33] (INSIDE HEIGHT) B 3.00 [.12] 120.00 [4.72] 107.00 [4.21] 108.06 [4.25] (INSIDE WIDTH) A A 3.00 [.12] B TOP VIEW 90.50 [3.56] 112.13 [4.41] SECTION B-B END VIEW POLYCARBONATE VERSION ONLY 150.47 [5.92] 2.50 15.50 [.10] [.61] 6.00 [.24] [.15] 19.38 106.68 [.76] [4.20] 132.00 [5.20] 84.00 [3.31] 87.00 [3.43] 75.88 [2.99] 167.13 [6.58] R e comme nde d C ov e r scre w torque -- 2.5 lbf-in (30 cN -m) 155 4T 4X 4.00 [4X .16] MOUNTING HOLES 42.00 [1.65] 171.00 [6.73] Ge n e ral P urp ose  A BS RA L‐7035 P olycarbo nate  RA L‐7035 1554TGY 1554T2GY 1554T Cle a r / S m o ke L id En clo su re 152.00 [5.98] P olycarb onate  Box  / Cle ar P o lycarbonate  Lid P olycarbonate  Box  / Sm oke  P olycarb onate  Lid 1554T2GYCL 1554T2GYSL ACCES S O RIES S teel Inner P anels S teel P anel / P .C. B oard M ac hine S c rew [M 3 x 8m m P lated] S teel P anel / P .C. B oard S elf Tapping S c rew [#6 X 1/4" (6.4m m ) P lated] Cover S c rews (P k g 4) [M 4 X 20m m S tainles s S teel] S ilic one P re-form ed G as k et B lac k 113.00 [4.45] ACCEPTS #6 SELF-TAPPING SCREW INSIDE BOX (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 1554T Re g u la r En clo su re 155.88 [6.14] M3 BRASS INSERTS Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. P urc has ed as s em bly inc ludes box , lid, 4 c over s c rews , and preform ed s ilic one gas k et. G eneral P urpos e A B S vers ion is not UL approved. (M atl UL94 - HB ) P oly c arbonate vers ion is UL 508 approved. (M atl UL94 - 5V A @ 3m m ) 174.88 [6.89] 160.00 [6.30] US LISTED N OT E SECTION A-A SIDE VIEW 114.88 [4.52] 67.92 [2.67] STEEL PANEL ORDER SEPARATELY (INSIDE LENGTH) 167.00 [6.57] ® FILE #E65324 NEMA 4, 4X 3.73 75.00 [2.95] 172.13 [6.78] UL O C 72.00 [2.83] 1554HP L 1591MM100 1598A TS100 SC1554 1554HGA SK ET R7.50 [.30] M4 STAINLESS STEEL INSERTS INSIDE LID Dimensions: mm [inches] 1554T www.hammondmfg.com ®
1554TGY 价格&库存
很抱歉,暂时无法提供与“1554TGY”相匹配的价格&库存,您可以联系我们找货
1554TGY
  • 1+275.671671+32.95670
  • 5+235.550975+28.16025
  • 10+220.1193710+26.31539
  • 25+201.2747525+24.06251
  • 50+188.0987350+22.48731
  • 100+187.05785100+22.36287
库存:64
