1455
Extruded Aluminum
Key Features:
• Designed to house P.C. boards or for equipment interfacing.
• Sized for standard Eurocards.
• P.C. boards mount horizontally by sliding into internal slots extruded into
the enclosure body.
• Rugged body constructed from extruded aluminum with a minimum
thickness of .06” (1.5 mm).
• Extruded body includes a slide removable “belly” plate - except in
smaller sizes “A” through “D”
Includes:
• Two aluminum end panels - finish matched to extruded aluminum
body (or link here if you prefer our solid plastic end panel version)
• Two black ABS plastic bezels (your option to install)
• Extruded aluminum body - choice of clear, black, blue or red anodized
finish
• Self adhesive rubber feet. Replacements are available - order part
number 1421T2CL (pack of 24).
• All hardware - end panel screws are #6 x 3/8” TTT - thread rolling, steel
screws with a #4 flat head phillips drive. Zinc plate finish - either clear or
black (black screws are used on the black, blue & red models).
• For black replacement screws (quantity 100) order part number
1455MS100BK
• For clear replacement screws (quantity 100) order part number
1455MS100
• NOTE: Recommended screw torque is 5 lbf/in
Extras
Replacement
Rubber Feet
(24-pack)
1421T2CL
Replacement
Screws (100-pack)
1455MS100BK
www.hammondmfg.com
1455MS100
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
60
1455
Extruded Aluminum
Most models feature a
slide-in belly plate for
easy access to the inside of the enclosure.
All models feature
internal PC board slots
for easy mounting and
assembly.
Accessories
Plastic bezels available in 5
colors: Yellow, Red, Transparent Red, Black, and
Transparent Blue.
Mix and match colors with
extra end panels. Available in four anodized
finishes: black, clear, red,
and blue.
Flanged end panels kits
are available in clear or
black anodize. Both come
with black screws.
Refer to accessories table for part numbers.
www.hammondmfg.com
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
61
1455
Extruded Aluminum
Part Number With
Aluminum End
Panels
Part Number With
Plastic End Panels
1455D601
1455D602
Clear
1455D601BK
1455D602BK
Black
Anodized Color
1455D601BU
Blue
1455D601RD
Red
1455D801
1455D802
Clear
1455D801BK
1455D802BK
Black
1455D801BU
Blue
1455D801RD
Units
Length
Width
Height
Inches
mm
2.36
60
1.76
45
0.99
25
Inches
mm
3.15
80
1.76
45
0.99
25
Inches
mm
3.15
80
2.76
70
0.47
12
Inches
mm
3.15
80
2.82
71.7
0.75
19
Inches
mm
3.15
80
2.13
54
0.91
23
Inches
mm
3.94
100
2.76
70
0.47
12
Inches
mm
3.94
100
2.82
71.7
0.75
19
Inches
mm
4.72
120
2.76
70
0.47
12
Inches
mm
4.72
120
2.82
71.7
0.75
19
Inches
mm
4.72
120
2.13
54
0.91
23
Red
1455A802
Clear
1455A802BK
Black
1455A802BU
Blue
1455A802RD
Red
1455B802
Clear
1455B802BK
Black
1455B802BU
Blue
1455B802RD
Red
1455C801
1455C802
Clear
1455C801BK
1455C802BK
Black
1455C801BU
1455C802BU
Blue
1455C801RD
1455C802RD
Red
1455A1002
Clear
1455A1002BK
Black
1455A1002BU
Blue
1455A1002RD
Red
1455B1002
Clear
1455B1002BK
Black
1455B1002BU
Blue
1455B1002RD
Red
1455A1202
Clear
1455A1202BK
Black
1455A1202BU
Blue
1455A1202RD
Red
1455B1202
Clear
1455B1202BK
Black
1455B1202BU
Blue
1455B1202RD
Red
1455C1201
1455C1202
Clear
1455C1201BK
1455C1202BK
Black
1455C1201BU
Blue
1455C1201RD
Red
www.hammondmfg.com
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
62
1455
Part Number With
Aluminum End
Panels
Part Number With
Plastic End Panels
Extruded Aluminum
Anodized Color
1455J1201
1455J1202
Clear
1455J1201BK
1455J1202BK
Black
1455J1201BU
Blue
1455J1201RD
Units
Length
Width
Height
Inches
mm
4.72
120
3.07
78
1.06
27
Inches
mm
4.72
120
3.07
78
1.69
43
Inches
mm
4.72
120
4.06
103
1.2
30.5
Inches
mm
4.72
120
4.06
103
2.09
53
Inches
mm
6.3
160
3.07
78
1.06
27
Inches
mm
6.3
160
3.07
78
1.69
43
Inches
mm
6.3
160
4.06
103
1.2
30.5
Inches
mm
6.3
160
4.06
103
2.09
53
Inches
mm
6.3
160
4.92
125
1.2
30.5
Inches
mm
6.3
160
4.92
125
2.03
51.5
Red
1455K1201
1455K1202
Clear
1455K1201BK
1455K1202BK
Black
1455K1201BU
Blue
1455K1201RD
Red
1455L1201
1455L1202
Clear
1455L1201BK
1455L1202BK
Black
1455L1201BU
Blue
1455L1201RD
Red
1455N1201
1455N1202
Clear
1455N1201BK
1455N1202BK
Black
1455N1201BU
Blue
1455N1201RD
Red
1455J1601
1455J1602
Clear
1455J1601BK
1455J1602BK
Black
1455J1601BU
Blue
1455J1601RD
Red
1455K1601
1455K1602
Clear
1455K1601BK
1455K1602BK
Black
1455K1601BU
Blue
1455K1601RD
Red
1455L1601
1455L1602
Clear
1455L1601BK
1455L1602BK
Black
1455L1601BU
Blue
1455L1601RD
Red
1455N1601
1455N1602
Clear
1455N1601BK
1455N1602BK
Black
1455N1601BU
Blue
1455N1601RD
Red
1455P1601
1455P1602
Clear
1455P1601BK
1455P1602BK
Black
1455P1601BU
Blue
1455P1601RD
Red
1455Q1601
1455Q1602
Clear
1455Q1601BK
1455Q1602BK
Black
1455Q1601BU
Blue
1455Q1601RD
Red
www.hammondmfg.com
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
63
1455
Part Number With
Aluminum End
Panels
Part Number With
Plastic End Panels
Extruded Aluminum
Anodized Color
1455R1601
1455R1602
Clear
1455R1601BK
1455R1602BK
Black
1455R1601BU
Blue
1455R1601RD
Units
Length
Width
Height
Inches
mm
6.3
160
6.5
165
1.2
30.5
Inches
mm
6.3
160
6.5
165
2.03
51.5
Inches
mm
8.66
220
4.06
103
1.2
30.5
Inches
mm
8.66
220
4.06
103
2.09
53
Inches
mm
8.66
220
4.92
125
1.2
30.5
Inches
mm
8.66
220
4.92
125
2.03
51.5
Inches
mm
8.66
220
6.5
165
1.2
30.5
Inches
mm
8.66
220
6.5
165
2.03
51.5
Red
1455T1601
1455T1602
Clear
1455T1601BK
1455T1602BK
Black
1455T1601BU
Blue
1455T1601RD
Red
1455L2201
1455L2202
Clear
1455L2201BK
1455L2202BK
Black
1455L2201BU
Blue
1455L2201RD
Red
1455N2201
1455N2202
Clear
1455N2201BK
1455N2202BK
Black
1455N2201BU
Blue
1455N2201RD
Red
1455P2201
1455P2202
Clear
1455P2201BK
1455P2202BK
Black
1455P2201BU
Blue
1455P2201RD
Red
1455Q2201
1455Q2202
Clear
1455Q2201BK
1455Q2202BK
Black
1455Q2201BU
Blue
1455Q2201RD
Red
1455R2201
1455R2202
Clear
1455R2201BK
1455R2202BK
Black
1455R2201BU
Blue
1455R2201RD
Red
1455T2201
1455T2202
Clear
1455T2201BK
1455T2202BK
Black
1455T2201BU
Blue
1455T2201RD
Red
www.hammondmfg.com
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
64
1455
For
Part
Number
Starting
With
Extruded Aluminum
Black
2-pack
10-pack
Red
Yellow
2-pack
10-pack
1455A
1455APLBK 1455APLBK-10
1455B
1455BPLBK
1455C
1455CPLBK 1455CPLBK-10 1455CPLY
1455D
1455DPLBK 1455DPLBK-10
2-pack
Translucent Red
10-pack
2-pack
10-pack
Translucent Blue
2-pack
10-pack
1455BPLBK-10
1455CPLY-10
1455CPLRED 1455CPLRED-10 1455CPLTRD 1455CPLTRD-10 1455CPLTBU 1455CPLTBU-10
1455J
1455JPLBK
1455JPLBK-10
1455JPLY
1455JPLY
1455JPLRED
1455JPLRED-10
1455K
1455KPLBK
1455KPLBK-10 1455KPLY
1455KPLY
1455KPLRED
1455KPLRED-10 1455KPLTRD
1455KPLTRD-10 1455KPLTBU 1455KPLTBU-10
1455L
1455LPLBK
1455LPLBK-10
1455LPLY
1455LPLRED
1455LPLRED-10
1455LPLTRD-10
1455LPLY
1455JPLTRD
1455LPLTRD
1455JPLTRD-10
1455JPLTBU
1455LPLTBU
1455JPLTBU-10
1455LPLTBU-10
1455N
1455NPLBK 1455NPLBK-10 1455NPLY
1455NPLY
1455NPLRED 1455NPLRED-10 1455NPLTRD 1455NPLTRD-10 1455NPLTBU 1455NPLTBU-10
1455P
1455PPLBK
1455PPLBK-10 1455PPLY
1455PPLY
1455PPLRED
1455Q
1455QPLBK 1455QPLBK-10 1455QPLY
1455QPLY
1455QPLRED 1455QPLRED-10 1455QPLTRD 1455QPLTRD-10 1455QPLTBU 1455QPLTBU-10
1455R
1455RPLBK
1455RPLBK-10 1455RPLY
1455RPLY
1455RPLRED
1455RPLRED-10 1455RPLTRD
1455RPLTRD-10 1455RPLTBU 1455RPLTBU-10
1455T
1455TPLBK
1455TPLBK-10
1455TPLY
1455TPLRED
1455TPLRED-10
1455TPLTRD-10
For
Part
Number
Starting
With
1455TPLY
Yellow
Black
2-pack
10-pack
1455C
1455CBBK
1455CBBK-10
1455D
1455DBBK
1455DBBK-10
1455J
1455JBBK
1455K
1455L
2-pack
1455PPLRED-10 1455PPLTRD
1455TPLTRD
1455PPLTRD-10 1455PPLTBU 1455PPLTBU-10
Translucent Red
Red
1455TPLTBU
1455TPLTBU-10
Translucent Blue
10-pack
2-pack
10-pack
2-pack
10-pack
2-pack
10-pack
1455CBY
1455CBY-10
1455CBRED
1455CBRED-10
1455CBTRD
1455CBTRD-10
1455CBTBU
1455CBTBU-10
1455DBY
1455DBY-10
1455DBRED
1455DBRED-10
1455DBTRD
1455DBTRD-10
1455DBTBU
1455DBTBU-10
1455JBBK-10
1455JBY
1455JBY-10
1455JBRED
1455JBRED-10
1455JBTRD
1455JBTRD-10
1455JBTBU
1455JBTBU-10
1455KBBK
1455KBBK-10
1455KBY
1455KBY-10
1455KBRED
1455KBRED-10
1455KBTRD
1455KBTRD-10
1455KBTBU
1455KBTBU-10
1455LBBK
1455LBBK-10
1455LBY
1455LBY-10
1455LBRED
1455LBRED-10
1455LBTRD
1455LBTRD-10
1455LBTBU
1455LBTBU-10
1455N
1455NBBK
1455NBBK-10
1455NBY
1455NBY-10
1455NBRED
1455NBRED-10
1455NBTRD
1455NBTRD-10
1455NBTBU
1455NBTBU-10
1455P
1455PBBK
1455PBBK-10
1455PBY
1455PBY-10
1455PBRED
1455PBRED-10
1455PBTRD
1455PBTRD-10
1455PBTBU
1455PBTBU-10
1455Q
1455QBBK
1455QBBK-10
1455QBY
1455QBY-10
1455QBRED
1455QBRED-10
1455QBTRD
1455QBTRD-10
1455QBTBU
1455QBTBU-10
1455R
1455RBBK
1455RBBK-10
1455RBY
1455RBY-10
1455RBRED
1455RBRED-10
1455RBTRD
1455RBTRD-10
1455RBTBU
1455RBTBU-10
1455T
1455TBBK
1455TBK-10
1455TBY
1455TBY-10
1455TBRED
1455TBRED-10
1455TBTRD
1455TBTRD
1455TBTBU
1455TBTBU-10
www.hammondmfg.com
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
65
1455
Extruded Aluminum
For
Part Number
Starting With
Clear Anodize
Black Anodize
Blue Anodize
Red Anodize
10-pack
10-pack
10-pack
10-pack
1455C
1455CAL-10
1455CALBK-10
1455CALBU-10
1455CALRD-10
1455D
1455DAL-10
1455DALBK-10
1455DALBU-10
1455DALRD-10
1455J
1455JAL-10
1455JALBK-10
1455JALBU-10
1455JALRD-10
1455K
1455KAL-10
1455KALBK-10
1455KALBU-10
1455KALRD-10
1455L
1455LAL-10
1455LALBK-10
1455LALBU-10
1455LALRD-10
1455N
1455NAL-10
1455NALBK-10
1455NALBU-10
1455NALRD-10
1455P
1455PAL-10
1455PALBK-10
1455PALBU-10
1455PALRD-10
1455Q
1455QAL-10
1455QALBK-10
1455QALBU-10
1455QALRD-10
1455R
1455RAL-10
1455RALBK-10
1455RALBU-10
1455RALRD-10
1455T
1455TAL-10
1455TALBK-10
1455TALBU-10
1455TALRD-10
For
Part Number Starting With
Black Anodize
Clear Anodize
1455C
1455CF
1455CFBK
1455D
1455DF
1455DFBK
1455J
1455JF
1455JFBK
1455K
1455KF
1455KFBK
1455L
1455LF
1455LFBK
1455N
1455NF
1455NFBK
1455P
1455PF
1455PFBK
1455Q
1455QF
1455QFBK
1455R
1455RF
1455RFBK
1455T
1455TF
1455TFBK
Critical Data, No Questions
PDF Data Sheets, 2D AutoCAD, and
3D Models are available for download immediately from our web site.
www.hammondmfg.com
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
66
很抱歉,暂时无法提供与“1455N1201RD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+234.22803
- 10+224.85557
- 20+215.50395
- 国内价格 香港价格
- 1+283.863951+36.40860
- 10+236.5532910+30.34050
- 50+220.6949750+28.30650
- 国内价格 香港价格
- 1+318.531131+40.85504
- 5+268.353785+34.41926
- 10+249.4398910+31.99335
- 25+226.5981125+29.06365
- 50+210.8028750+27.03774
- 100+201.54561100+25.85039
