1553TGYBAT
1553TGYBAT
    HAMMONDMANUFACTURING
    BOX ABS GRAY 8.27"L X 3.94"W
1553TGYBAT 数据手册
Rear View of Assembly Top View of Assembly 100.0 [3.94] SECTION A-A (Side View of Assembly) 83.24 [3.28] 56.00 [2.20] (Inlay Width) 32.00 [1.26] A (Inlay Width) 42.00 [1.65] 63.95 [2.52] (Inlay Length) (Inlay Length) 210.0 [8.27] Battery Holder 124.24 [4.89] (Inlay length) Removable Panel .50 [.02] (Rear Inlay Depth) 1.50 [.06] (Top Inlay Depth) 5.00 [.20] 2.75 [.11] (Wall Thickness) 66.62 [2.62] 55.00 [2.17] 25.00 [.98] (Inner Box Height) A 69.05 [2.72] 85.9 [3.38] (Inlay Width) Top End View of Assembly 6.30 Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Enclosure made from FR ABS (UL 94‐V0) plastic. 82.00 [3.23] 55.00 [2.17] 9.0 [.35] Purchased assembly includes Top, Bottom, front plastic panel, Battery Door, battery spring clips (4 pcs), 9V adapter (1pcs) and 6Cover Screws. M3 Brass Inserts are Pre-Installed. 20.95 [.82] Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) [.25] PART NUMBER 24.25 [.95] (Viewing Area) 40.00 [1.57] 62.70 [2.47] 9.0 [.35] 50.00 [1.97] Front Panel 65.28 [2.57] Black Enclosure/Grey Over‐mold Grey Enclosure/Grey Over‐mold Cover screw (Pkg 100) [M3-0.5 X 18mm] 8 PCB Posts on Top 55.00 [2.17] 10 PCB Posts on Bottom PCB post accepts #4 X 1/4" self tap screw 27.50 [1.08] 1553T Battery Enclosure 1553TBKBAT 1553TGYBAT ACCESSORIES 28.00 [1.10] (Viewing Area) 9.0 [.35] Drawings available for maximum P.C Board size. P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] Belt or Pocket Clip 9V Battery Kit AA Battery Clip Kit (4 positive and 4 Negative) 1594MS100 (silver) 1594MS100BK (Black) 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) 1599CLIP (Black) 1599CLIPGY (Grey) BS61 1553HDR‐BKIT M3 Insert for Cover Screws 2.75 [.11] Inside View of Top Inside View of Bottom Dimensions: mm [inches] 1553TBAT www.hammondmfg.com ®
1553TGYBAT 价格&库存
很抱歉,暂时无法提供与“1553TGYBAT”相匹配的价格&库存,您可以联系我们找货
1553TGYBAT
  • 1+257.174691+32.25020
  • 10+214.2822110+26.87140
  • 50+200.0447950+25.08600
