1591XXBGY
1591XXBGY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 4.48"L X 2.49"W
1591XXBGY 数据手册
113.82 [4.48] 27.00 [1.06] INSIDE HEIGHT 100.00 [3.94] B 63.32 [2.49] A A B TOP VIEW 6.50 [.26] LID HEIGHT 6.11 [.24] 4.34 [.17] M3-0.5 X10mm MACHINE SCREW 28.25 [1.11] BOX HEIGHT 57.65 [2.27] INSIDE WIDTH 31.00 [1.22] SECTION B-B END VIEW 108.00 [4.25] 41.50 [1.63] 57.50 [2.26] 108.15 [4.26] INSIDE LENGTH 4.50 [.18] 49.50 [1.95] 2.00 [.08] WALL THICKNESS 92.00 [3.62] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE SECTION A-A SIDE VIEW 77.50 [3.05] 36.50 [1.44] R3.50 [.14] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE 3.50 [.14] 111.35 [4.38] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 106.94 [4.21] Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS 60.85 [2.40] 5.00 [.20] 36.50 [1.44] 56.44 [2.22] 36.50 [1.44] 5.00 [.20] 77.50 [3.05] INSIDE BOX M3-0.5 BRASS INSERTS INSTALLED BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW 77.50 [3.05] 1591XXB Enclosure 1591XXBBK 1591XXBGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] Black Textured Enclosure Gray Textured Enclosure 4X 3.50 THRU  6.00 X 82° INSIDE LID Dimensions: mm [inches] 1591XXB www.hammondmfg.com ®
1591XXBGY
物料型号:1591XXB 器件简介:这是一个由Hammond Manufacturing生产的塑料外壳,用于容纳和保护电路板。
引脚分配:外壳内设有M3-0.5铜螺母安装孔,用于固定电路板。
参数特性:外壳尺寸为113.82mm x 100.00mm x 27.00mm,内部尺寸为63.32mm x 57.65mm x 49.50mm,材质为FRABS UL 94-V0塑料,颜色有黑色和灰色可选。
功能详解:外壳设计用于容纳电路板,提供物理保护。
盖子高度为28.25mm,盒子高度为108.00mm。
应用信息:适用于需要物理保护和外观整洁的电路板应用。
封装信息:外壳由FRABS UL 94-V0塑料制成,颜色为黑色或灰色,盖子螺丝为M3-0.5 x 10mm,有黑色和镀层可选。
1591XXBGY 价格&库存
很抱歉,暂时无法提供与“1591XXBGY”相匹配的价格&库存,您可以联系我们找货
1591XXBGY
  • 1+46.902061+6.07940
  • 10+39.2303510+5.08500
  • 50+36.5278250+4.73470
