1591XXLGY
1591XXLGY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 3.43"L X 2.28"W
1591XXLGY 数据手册
87.08 [3.43] B A A B 6.50 [.26] LID HEIGHT 35.00 [1.38] INSIDE HEIGHT 72.70 [2.86] 43.50 [1.71] 2.00 [.08] WALL THICKNESS 57.88 [2.28] 39.00 [1.54] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 6.10 [.24] TOP VIEW 4.34 [.17] 36.25 [1.43] BOX HEIGHT 80.00 [3.15] 35.50 [1.40] 4.50 [.18] 51.65 [2.03] INSIDE WIDTH 80.85 [3.18] INSIDE LENGTH 51.00 [2.01] 64.50 [2.54] 30.50 [1.20] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE SECTION A-A SIDE VIEW Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. R4.00 [.16] 50.20 [1.98] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE 3.50 Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m [.14] 80.20 [3.16] 84.61 [3.33] PART NUMBERS 5.00 5.00 55.41 [2.18] [.20] 50.20 [1.98] INSIDE BOX 30.50 [1.20] M3-0.5 BRASS INSERTS INSTALLED BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW [.20] 51.00 [2.01] 50.20 [1.98] 30.50 [1.20] 1591XXL Enclosure 1591XXLBK 1591XXLGY ACCESSORIES Black Cover Screws [M3-0.5 X10mm] 1591MS100BK (Pkg 100) Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] Black Textured Enclosure Gray Textured Enclosure 4X 3.50 THRU  6.00 X 82° INSIDE LID Dimensions: mm [inches] 1591XXL www.hammondmfg.com ®
1591XXLGY
1. 物料型号:1591XXL Enclosure,这是一个由FR ABS UL 94-V0塑料制成的外壳,具有黑色纹理和灰色纹理的选项。
2. 器件简介:外壳采用M3-0.5 x10mm的机器螺丝,推荐扭矩为(43-50) ozf.in或(30-35) cN.m。外壳包括盒子、盖子、4个盖子螺丝和已安装的黄铜嵌件。
3. 引脚分配:文档中提到了盖子螺丝和PCB板螺丝的规格,但没有提供详细的引脚分配图。
4. 参数特性:外壳的尺寸包括内部宽度51.65mm [2.03英寸],内部长度80.00mm [3.15英寸],盖子高度6.50mm [0.26英寸],盒子高度36.25mm [1.43英寸]。
5. 功能详解:外壳可以进行工厂修改(铣削、钻孔、打印等),以适应不同的需求。可以联系工厂获取报价和STEP或IGES格式的实体模型。
6. 应用信息:外壳适用于容纳最大尺寸为64.50mm [2.54英寸] x 51.00mm [2.01英寸]的PCB板。
7. 封装信息:外壳的封装信息包括内部尺寸和外部尺寸,以及盖子和盒子的详细视图。
1591XXLGY 价格&库存
很抱歉,暂时无法提供与“1591XXLGY”相匹配的价格&库存,您可以联系我们找货
1591XXLGY
  • 1+62.16020
库存:19
1591XXLGY
  • 1+36.091921+4.67820
  • 10+29.9894310+3.88720
  • 50+27.9843250+3.62730
库存:9
