1553CBKBAT
1553CBKBAT
    HAMMONDMANUFACTURING
    BOX ABS BLACK 4.62"L X 3.11"W
1553CBKBAT 数据手册
Top View of Assembly SECTION B-B (Side View Inside Assembly) 59.43 [2.340] (Center Inlay Width) 27.00 [1.063] (Inner Box Height) B 117.24 [4.616] 5.00 [.197] (Boss Height) 100.43 [3.954] (Inlay Length) R353.48 [13.917] Top Cover Bottom Cover B 52.35 [2.061] (End Inlay Width) 78.97 [3.109] Inside of Bottom Cover Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 40.00 [1.575] End View of Assembly (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Bottom Cover .50 [.020] (Inlay Depth) 57.83 [2.277] 56.68 [2.232] 56.47 [2.223] 70.46 [2.774] 63.22 (Inner Box Width [2.489] at Center) (Inner Box Width at End) Enclosure molded from GP ABS Plastic.  Purchased assembly includes Top, Bottom, front plastic panel, Battery Door, battery spring clips (4 pcs), 9V adapter (1pcs) and 2 cover screws. (P.C. Board not supplied) Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) Front Panel PART NUMBER 5.50 108.91 [4.288] (Inner Box Length) 32.00 [1.260] 1553C Battery Enclosure [.217] Black Enclosure/Grey Over‐mold Grey Enclosure/Grey Over‐mold 1553CBKBAT 1553CGYBAT ACCESSORIES 27.50 [1.083] Front Panel 3.20 65.28 [2.570] Oval Head Cover Screws Self-Tapping (Pkg 100) [#4 X 1" (25.4mm)] Maximum P.C. Board Size P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] 78.18 [3.078] [.126] Belt or Pocket Clip 62.48 [2.460] (Viewing Area) 2.75 [.108] 24.50 [.965] (Viewing Area) 68.73 [2.706] 57.83 [2.277] 10.90 [.429] 9V Battery Kit AA Battery Clip Kit (4 positive and 4 Negative) 6.33 56.75 [2.234] [.249] 56.68 [2.232] SC1553C100 (Silver) SC1553C100BK (Black) 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) 1599CLIP (Black) 1599CLIPGY (Grey) BS61 1553HDR‐BKIT 60.78 [2.393] (NOT SUPPLIED) 40.00 [1.575] R357.35 [14.069] Dimensions: mm [inches] 1553CBAT www.hammondmfg.com ®
1553CBKBAT 价格&库存
很抱歉,暂时无法提供与“1553CBKBAT”相匹配的价格&库存,您可以联系我们找货
1553CBKBAT
    • 1+119.43630
    库存:9
    1553CBKBAT
    • 1+163.367651+21.07485
    • 5+137.464695+17.73330
    • 10+127.7040810+16.47416
    • 25+115.9326025+14.95560
    • 50+107.8053450+13.90717
    • 100+100.28111100+12.93652
    • 250+94.21753250+12.15431
    库存:25
