1553TTBK
1553TTBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 6.5"L X 3.15"W
1553TTBK 数据手册
Rear View of Assembly SECTION A-A (Side View of Assembly) Top View of Assembly 80.0 [3.15] 67.31 [2.65] (Inlay Width) 44.00 [1.73] 28.00 [1.10] A (Inlay Width) 50.95 [2.01] (Inlay Length) 33.00 [1.30] (Inlay Length) Removable Panel 1.50 [.06] (Top Inlay Depth) .50 [.02] (Rear Inlay Depth) 5.00 [.20] 165.0 [6.50] 96.31 [3.79] (Inlay Length) 5.17 [.20] 2.25 [.09] (Wall Thickness) 22.00 [.87] (Inner Box Height) A 67.95 [2.68] 54.11 [2.13] (Inlay Width) Top End View of Assembly 65.00 [2.56] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Enclosure made from FR ABS (UL 94‐V0) plastic. 7.50 [.30] 9.00 [.35] 35.00 [1.38] 18.48 [.73] Purchased assembly includes Top, Bottom, front and rear plastic panels and 6Cover Screws. M3 Brass Inserts are Pre-Installed. Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) 20.30 [.80] (Viewing Area) 47.80 [1.88] (Viewing Area) Front/Rear Panel 30.00 [1.18] 7.5 [.29] Black Enclosure/Grey Over‐mold Grey Enclosure/Grey Over‐mold 21.00 [.83] 40.00 [1.57] 1553TTBK 1553TTGY ACCESSORIES 45.00 [1.77] 49.94 [1.97] 10 PCB Posts on Top 12 PCB Posts on Bottom Cover screw (Pkg 100) [M3-0.5 X 18mm] P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] Belt or Pocket Clip PCB post accepts #4 X 1/4" self tap screw 44.00 [1.73] 22.54 [.89] PART NUMBER 1553TT Regular Enclosure M3 Insert for Cover Screws 2.75 [.11] Inside View of Top 1594MS100 (silver) 1594MS100BK (Black) 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) 1599CLIP (Black) 1599CLIPGY (Grey) Drawings available for maximum P.C Board size. Inside View of Bottom Dimensions: mm [inches] 1553TT www.hammondmfg.com ®
1553TTBK 价格&库存
很抱歉,暂时无法提供与“1553TTBK”相匹配的价格&库存,您可以联系我们找货
