1598GSGY
1598GSGY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 9.83"L X 6.26"W
1598GSGY 数据手册
2 1 SECTION A-A (Side View Inside Assembly) Bottom View of Assembly A Top Cover Front Face n11.58 n 9.16 [.456] (Bottom Boss n) B Detail View of Boss (Located on Top and Bottom Cover) [.361] (Top Boss n) 3.20 [.126] 249.70 [9.831] B n 8.10 [.319] P.C. Board A 68.00 [2.677] (Inner Box Height) 138.40 [5.449] SECTION B-B (Inside of Bottom Cover) End View of Assembly B Top Cover 2.79 [.110] (PCB dist from inner wall) End Panel 159.00 [6.260] .50 [.020] (PCB dist from end panel) NOTE Purchased Assembly includes top and bottom cover, front and end aluminum panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4 rubber feet. B 1598G Instrument Case 239.50 [9.429] (Inner Box Length) 75.00 [2.953] Front/Rear Panel (Dashed Line Indicates Viewing Area) 145.90 [5.744] (Viewing Area) A 67.00 [2.638] (Viewing Area) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Solid models of this enclosure available in STEP or IGES. Contact Factory mjm@hammondmfg.com 149.14 [5.872] (Inner Box Width) 69.50 [2.736] P.C. Board Aligned on Bosses Maximum P.C. Board Size 27.33 [1.076] 113.00 [4.449] 143.57 88.90 [5.652] [3.500] 12.49 [.492] P.C. Board (Not Supplied) 8.83 [.348] n3.51 X 4 FLAME RETARDANT ABS (UL94-VO) 1598GBK Black Enclosure w ith Alum inum Pa nels 1598GGY Gre y Enclosure w ith Aluminum Pa ne ls 1598RGBK Bla ck EMI/RFI Shielded NON-FLAME RETARDANT GPABS (UL94-HB) 1598GSGY Gre y Enclosure w ith Aluminum Pa ne ls 1598GSGYPBK Grey Enclosure w ith Black Pla stic Pane ls ACCESSORIES 1598PLGBK Bla ck Pla stic Pa ne ls 1421T2 Rubber Fe e t (Pkg 24) For 1598 FR-ABS 1591MS100 Cover Screws (Pk g 100) [M3 - 0.5 x 10mm] For 1598 GPABS 1591TS100 Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)] For Both Mode ls 1598ATS100 PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)] [.138] 151.00 [5.945] 1.65 [.065] 42.40 [1.669] 1598G 153.70 [6.051] 238.50 [9.390] 2 1 A
1598GSGY 价格&库存
很抱歉,暂时无法提供与“1598GSGY”相匹配的价格&库存,您可以联系我们找货
1598GSGY
  • 1+184.185381+23.09720
  • 10+166.5237710+20.88240
  • 50+148.0511650+18.56590
1598GSGY
    • 1+150.40705
    库存:3
