1555J2F17GY
1555J2F17GY
    HAMMONDMANUFACTURING
    BOX PLASTIC GRAY 6.3"L X 3.57"W
1555J2F17GY 数据手册
200.79 [7.90] 19.60 [.77] A 4.60 [.18] 8.50 22.20 [.87] 180.79 [7.12] 83.75 [3.30] INLAY WIDTH B B 2.00 [.08] INLAY DEPTH 55.08 [2.17] 90.79 [3.57] A 3.00 [.12] 3.00 [.12] 17.70 [.70] INNER BOX DEPTH [.33] 4X 5.00 [4X .20] 15.50 [.61] 117.68 [4.63] INLAY LENGTH 12.00 [.47] INNER LID DEPTH SECTION A-A END VIEW ENCLOSURE ASSEMBLY TOP VIEW 19.95 [.79] 37.82 [1.49] 6.00 [.24] 8X 3.00  1.63 [8X .12  .06] POLYCARBONATE VERSION ONLY 76.00 [2.99] 6.00 [.24] 10.59 [.42] SECTION B-B SIDE VIEW UL O C STEEL PANEL ORDER SEPARATELY US LISTED Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 6.64 [.26] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 148.00 [5.83] 159.95 [6.30] 147.00 [5.79] ® FILE #E65324 NEMA 4, 4X NOTE Purchased assembly includes styled box, flanged lid, 4 cover screws, and preformed silicone gasket. General Purpose ABS version is not UL approved. (Matl UL94 - HB) Polycarbonate version is UL 508 approved. (Matl UL94 - 5VA @ 3mm) 4M STAINLESS STEEL INSERT 8X 2.25  6.00 [8X .09  .24] 153.00 [6.02] 134.00 Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) [5.28] 1555JF 1555JF Regular Enclosure 89.95 [3.54] 45.00 [1.77] 45.88 [1.81] 84.88 [3.34] 44.00 [1.73] 83.00 [3.27] 135.00 [5.31] 154.00 [6.06] INSIDE BOX VIEW 4X 3.50 THRU [4X .14 THRU] 3.00 [.12] 7.25 [.29] 83.00 [3.27] 6.79 [.27] 58.00 [2.28] 60.75 [2.39] INSIDE LID VIEW 15.00 [.59] General Purpose ABS RAL‐7035 Polycarbonate RAL‐7035 1555JF17GY 1555J2F17GY ACCESSORIES Steel Inner Panels Steel Panel / P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] Cover Screws (Pkg 4) [M4 X 20mm Stainless Steel] 1555JFPL 1555TS100 SC1554 7.00 [.28] Dimensions: mm [inches] 1555JF17 www.hammondmfg.com ®
1555J2F17GY 价格&库存
很抱歉,暂时无法提供与“1555J2F17GY”相匹配的价格&库存,您可以联系我们找货
1555J2F17GY
  • 1+169.43344
  • 3+160.12856
  • 10+157.76004
  • 50+154.03809
