1590Z100
1590Z100
    HAMMONDMANUFACTURING
    BOX ALUM UNPAINTED 2.94"LX3.13"W
1590Z100 数据手册
68.00 [2.68] 45.00 [1.77] 79.60 [3.13] (INSIDE DEPTH) A 6.00 [.24] 63.00 [2.48] B 12.00 [.47] 46.11 [1.82] 74.60 [2.94] B A TOP VIEW 65.74 [2.59] (INSIDE WIDTH) 52.00 [2.05] SECTION A-A END VIEW 1.50 [.06] 52.40 [2.06] 41.50 [1.63] 3.36 [.13] (AVERAGE WALL THICKNESS) ACCEPTS M4 - 0.7 MACHINE SCREW 23.75 [.94] UL O C US LISTED ® FILE #E65324 NEMA 4, 4X 70.51 [2.78] 56.00 [2.20] 62.60 [2.46] (INSIDE LENGTH) 13.99 [.55] 15.00 [.59] C SECTION B-B SIDE VIEW 68.28 [2.69] 44.73 [1.76] ACCEPTS M4 MACHINE GROUND SCREW Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 50.66 67.06 [1.99] [2.64] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) C NOTE Purchased assembly includes box, lid, silicone gasket, 4 cover screws and 2 ground screws with washers. Box and lid are made from Diecast Aluminum Alloy. 48.06 [1.89] 72.06 [2.84] Recommended cover screw Torque 5-7.5 lbf.in ( 50 -75 cN.m) DRAWINGS AVALIBLE FOR STEEL INNER PANEL INSIDE BOX Basic Enclosure Black Enclosure 47.53 [1.87] 63.00 [2.48] Grey Enclosure - RAL7001 Gloss 3.50 [.14] INSIDE LID 1590Z100 1590Z100BK 1590Z100GY ACCESSORIES 63.28 [2.49] 68.00 [2.68] 1590Z100 1590Z100 Enclosure 8.00 [.31] Steel Inner Panel 1590Z100PL Pre-Formed Silicone Gasket Copper Ground Hardware (2 Pack) [M4 - 0.7 X 6mm / M4 Washer] 1590Z100G 7.44 [.29] SECTION C-C MOUNTING HOLE 4.50 [.18] SCGM4 ® Dimensions: mm [inches] 1590Z100 www.hammondmfg.com
1590Z100
1. 物料型号: - 基本外壳型号为1590Z100,有黑色(1590Z100BK)和灰色(RAL7001,1590Z100GY)两种颜色可选。
2. 器件简介: - 该器件为Hammond公司生产的1590Z100系列外壳,包含盒子、盖子、硅胶垫圈、4个盖子螺丝和2个接地螺丝及垫圈。盒子和盖子由压铸铝合金制成。
3. 引脚分配: - 该外壳接受M4 - 0.7规格的机械螺丝。
4. 参数特性: - 外壳内部尺寸为68.00mm x 63.00mm x 3.50mm,平均壁厚为3.36mm。盖子内部尺寸为68.00mm x 63.00mm。
5. 功能详解: - 外壳设计符合NEMA 4和4X标准,适用于需要防尘、防水保护的场合。外壳可以进行工厂修改,如铣削、钻孔、印刷等。
6. 应用信息: - 适用于需要IP等级保护的电子设备,如工业控制面板、传感器等。
7. 封装信息: - 提供钢制内面板(型号1590Z100PL)、预成型硅胶垫圈(型号1590Z100G)和铜制接地硬件(型号SCGM4)等配件。
1590Z100 价格&库存
很抱歉,暂时无法提供与“1590Z100”相匹配的价格&库存,您可以联系我们找货
