1555H2F17GY
1555H2F17GY
    HAMMONDMANUFACTURING
    BOX PLASTIC GRAY 7.09"L X 4.72"W
1555H2F17GY 数据手册
220.79 [8.69] 22.20 [.87] 200.79 [7.90] A 8.50 .49 [.02] INLAY DEPTH 19.60 [.77] 4.60 [.18] 113.78 [4.48] INLAY WIDTH B B 70.75 [2.79] 120.79 [4.76] A 3.00 [.12] 3.00 [.12] [.33] 4X 5.00 [4X .20] 17.70 [.70] INNER BOX DEPTH 148.87 [5.86] INLAY LENGTH 12.00 [.47] INNER LID DEPTH SECTION A-A END VIEW ENCLOSURE ASSEMBLY TOP VIEW 8.33 [.33] 37.71 [1.48] 6.00 [.24] 6X 3.57 [6X .14] 19.38 106.68 [.76] [4.20] 6.00 [.24] POLYCARBONATE VERSION ONLY UL O C STEEL PANEL ORDER SEPARATELY US LISTED Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 167.13 [6.58] 179.97 [7.09] ® FILE #E65324 NEMA 4, 4X 6.51 [.26] SECTION B-B SIDE VIEW 167.00 [6.57] 15.50 [.61] NOTE Purchased assembly includes styled box, flanged lid, 4 cover screws, and preformed silicone gasket. General Purpose ABS version is not UL approved. (Matl UL94 - HB) Polycarbonate version is UL 508 approved. (Matl UL94 - 5VA @ 3mm) 173.00 [6.81] 154.00 [6.06] 6X 2.25  6.00 [6X .09  .24] Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) 1555HF 1555HF Regular Enclosure 75.00 [2.95] 4M STAINLESS STEEL INSERT 114.00 [4.49] 107.00 [4.21] 119.97 [4.72] 113.00 [4.45] 74.00 [2.91] 3.00 84.00 [.12] [3.31] 14.00 [.55] 6.79 [.27] 7.00 [.28] 155.00 [6.10] 174.00 [6.85] INSIDE BOX VIEW 4X 3.50 THRU [4X .14 THRU] 74.00 [2.91] 15.00 [.59] General Purpose ABS RAL‐7035 Polycarbonate RAL‐7035 1555HF17GY 1555H2F17GY ACCESSORIES Steel Inner Panels Steel Panel / P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] Cover Screws (Pkg 4) [M4 X 20mm Stainless Steel] 1555HFPL 1555TS100 SC1554 132.00 [5.20] INSIDE LID VIEW Dimensions: mm [inches] 1555HF17 www.hammondmfg.com ®
1555H2F17GY 价格&库存
很抱歉,暂时无法提供与“1555H2F17GY”相匹配的价格&库存,您可以联系我们找货
1555H2F17GY
  • 1+258.342601+32.39574
  • 5+220.873975+27.69723
  • 10+206.4430710+25.88762
  • 25+188.8106225+23.67654
  • 50+176.4745250+22.12962
  • 100+173.36083100+21.73916
库存:81
