Rear View of Assembly
Top View of Assembly
100.0
[3.94]
SECTION A-A
(Side View of Assembly)
83.24
[3.28]
56.00
[2.20]
(Inlay Width)
32.00
[1.26]
A
(Inlay Width)
42.00
[1.65]
63.95
[2.52]
(Inlay Length)
(Inlay Length)
210.0
[8.27]
Battery
Holder
124.24
[4.89]
(Inlay length)
Removable Panel
.50
[.02]
(Rear Inlay
Depth)
1.50
[.06]
(Top Inlay Depth)
5.00
[.20]
2.75
[.11]
(Wall
Thickness)
66.62
[2.62]
55.00
[2.17]
25.00
[.98]
(Inner Box Height)
A
69.05
[2.72]
85.9
[3.38]
(Inlay Width)
Top End View of Assembly
6.30
Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.)
Contact Factory
mjm@hammondmfg.com for quotes
Solid models of this enclosure available in STEP or IGES.
(Part number and text placement/orientation on our products are subject to change,
we do not recommend using them as a locating reference for modification purposes)
NOTE
Enclosure made from FR ABS (UL 94‐V0) plastic.
82.00
[3.23]
55.00
[2.17]
9.0
[.35]
Purchased assembly includes Top, Bottom, front plastic panel, Battery
Door, battery spring clips (4 pcs), 9V adapter (1pcs) and 6Cover Screws.
M3 Brass Inserts are Pre-Installed.
20.95
[.82]
Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m)
[.25]
PART NUMBER
24.25
[.95]
(Viewing Area)
40.00
[1.57]
62.70
[2.47]
9.0
[.35]
50.00
[1.97]
Front Panel
65.28
[2.57]
Black Enclosure/Grey Over‐mold
Grey Enclosure/Grey Over‐mold
Cover screw (Pkg 100)
[M3-0.5 X 18mm]
8 PCB Posts
on Top
55.00
[2.17]
10 PCB Posts
on Bottom
PCB post accepts
#4 X 1/4" self
tap screw
27.50
[1.08]
1553T Battery Enclosure
1553TBKBAT
1553TGYBAT
ACCESSORIES
28.00
[1.10]
(Viewing Area)
9.0
[.35]
Drawings available
for maximum P.C
Board size.
P.C. Board Self Tapping Screw
[#4 X 1/4" (6.4mm) Plated]
Belt or Pocket Clip
9V Battery Kit
AA Battery Clip Kit (4 positive and 4 Negative)
1594MS100 (silver)
1594MS100BK (Black)
1593ATS50 (Pkg 50)
1593ATS100 (Pkg 100)
1599CLIP (Black)
1599CLIPGY (Grey)
BS61
1553HDR‐BKIT
M3 Insert for
Cover Screws
2.75
[.11]
Inside View of Top
Inside View of Bottom
Dimensions:
mm
[inches]
1553TBAT
www.hammondmfg.com
很抱歉,暂时无法提供与“1553TBKBAT”相匹配的价格&库存,您可以联系我们找货
