1550WGBK
1550WGBK
    HAMMONDMANUFACTURING
    BOX ALUM BLACK 8.74"L X 5.75"W
1550WGBK 数据手册
8 7 6 5 4 3 2 1 222.00 mm [8.740 in] 212.00 mm [8.346 in] D 55.10 mm [2.169 in] A B B D 127.46 mm [5.018 in] (Inner Screw Post Clearance) 136.00 mm 146.00 mm [5.354 in] [5.748 in] 139.46 mm [5.491 in] (Inner Box Width) SECTION A-A End View of Assembly A Top View of Assembly C 51.00 mm [2.008 in] C 222.00 mm [8.740 in] 2.00 mm [0.079 in] (Wall Thickness) 206.00 mm [8.110 in] 51.10 mm [2.012 in] (Inner Box Height) 215.46 mm [8.483 in] (Inner Box Length) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 142.00 mm 130.00 mm [5.591 in] [5.118 in] NOTE Purchased assembly includes box, lid, and 6 cover screws. Box and lid are made from Diecast Aluminum Alloy. EVA Foam Gasket supplied with Liquid Resistant Enclosures SECTION B-B Side View Of Assembly B 210.07 mm [8.270 in] B \ PART NUMBERS 1.47 mm [0.058 in] 1550G Enclosure Unfinishe d Bla ck Te x ture d Polye ste r Pow de r Pa int 1550W G Liquid Re sista nt Enclosure Unfinishe d Bla ck Te x ture d Polye ste r Pow de r Pa int M3.5 x 0.6 (Threaded Holes) Top View Looking Inside Box 1550G 1550GBK 1550W G 1550W GBK Acce ssorie s Recommended T orque: 75 ozf.in / 55 cN.m Unfinshe d Cove r Scre w s (Pkg 100) [M 3.5 x 0.6 18-8 SS] 1.50 mm [0.059 in] 1550MS100 134.07 mm [5.278 in] A n4.10 mm [0.161 in] 8 2.90 mm [0.114 in] View Looking Inside Lid 7 6 4.10 mm [0.161 in] 5 A 1550WG 4 3 2 1
1550WGBK
物料型号为1550WG,是Hammond Manufacturing公司生产的一款铝制外壳。
器件简介包括其尺寸为222.00 mm x 136.00 mm x 55.10 mm,内螺纹孔M3.5 x 0.6,以及内六角盖螺丝。
引脚分配未在文档中明确说明。
参数特性包括内螺纹孔规格、内六角盖螺丝规格、内盒尺寸、壁厚、内盒长度、宽度和高度。
功能详解涉及外壳的防水、防尘功能,以及EVA泡沫垫圈提供额外的液体防护。
应用信息指出该外壳适用于需要防护的电子设备。
封装信息包括材料为压铸铝合金,表面处理为未上漆或黑色纹理聚酯粉末涂料,以及盖子螺丝材质为18-8不锈钢。
购买的组装包括盒子、盖子和6个盖子螺丝。
1550WGBK 价格&库存
很抱歉,暂时无法提供与“1550WGBK”相匹配的价格&库存,您可以联系我们找货
1550WGBK
  • 1+287.336661+37.01880
  • 10+239.5349310+30.86030
  • 50+223.4840750+28.79240
库存:1
