1551USB1GY
1551USB1GY
    HAMMONDMANUFACTURING
    Box Plastic, ABS Gray Hand Held, Split Sides 1.378" L x 0.787" W (35.00mm x 20.00mm) X 0.610" (15.50...
1551USB1GY 数据手册
35.00 [1.38] 28.97 [1.14] 11.60 [.46] 15.50 [.61] A 13.97 20.00 [.55] [.79] B 12.52 [.49] 5.50 [.22] 16.41 [.65] B A 5.00 [.20] 3.74 [.15] .50 [.02] Inlay Depth 6.55 [.26] 29.00 [1.14] 5.00 [.20] 8.50 [.33] 1.70 [.07] 5.05 [.20] SECTION A-A 2.25 [.09] MAXIMUM P.C. BOARD SIZE (NOT SUPPLIED) 3.50 [.14] 31.41 [1.24] 18.00 [.71] SECTION B-B 11.00 13.10 15.50 [.43] [.52] [.61] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 2.00 NOTE [.08] Purchased assembly includes box, lid, 2 cover screws. Enclosure molded from general purpose ABS Plastic. Other materials / colours available consult factory. 3.45 [.14] Recommended Torque : (35-43) Ozf.in / (25-30) cN.m 9.31 [.37] Cover Screw accept #2x1/2" Self Tap screw 26.85 [1.06] 1.50 [.06] R2.25 [R.09] 1.20 [.05] 3.73 [.15] PART NUMBERS Mounting posts accept #2x3/16" Self Tap screw 14.00 [.55] 1551USB1 Enclosure 1551USB1BK Black Enclosure - Ral 9011 - UL94 - HB 1551USB1GY Gray Enclosure - RAL 7035 - UL94 - HB Translucent Blue - UL94 - HB 1551USB1TBU Translucent Clear - UL94 - HB 1551USB1CLR Translucent Smoke - UL94 - HB 1551USB1TSK 1551USB1TRD Translucent Red - UL94 - HB ACCESSORIES P.C. Board Plastite Self Tapping Screw 1553WTS100 (Pkg 100) [#2 x 3/16" self-tapping (4.8mm)] 1551USB50BK (Pkg 50) Black Cover Screws #2 X 1/2" Self-tapping 11.00 [.43] 18.00 [.71] 3.34 [.13] ® Dimensions: mm [inches] 1551USB1 www.hammondmfg.com
1551USB1GY 价格&库存
很抱歉,暂时无法提供与“1551USB1GY”相匹配的价格&库存,您可以联系我们找货
1551USB1GY
  • 1+22.980091+2.88150
  • 10+19.1951310+2.40690
  • 50+17.7532550+2.22610
库存:24
1551USB1GY
  • 1+25.77051
  • 8+18.88718
  • 21+17.79592
库存:24
