1591XXSBK
1591XXSBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 4.43"L X 3.33"W
1591XXSBK 数据手册
112.52 [4.43] 97.80 [3.85] 40.00 [1.57] INSIDE HEIGHT B 2.00 [.08] WALL THICKNESS 69.90 [2.75] A A B TOP VIEW 6.50 [.26] LID HEIGHT 6.11 [.24] 84.62 [3.33] 44.00 [1.73] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 105.79 [4.17] 4.34 [.17] 41.25 [1.62] BOX HEIGHT 4.50 [.18] 105.95 [4.17] INSIDE LENGTH 61.90 [2.44] 77.90 [3.07] 89.79 [3.54] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE SECTION A-A SIDE VIEW 56.90 [2.24] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. R3.51 [.14] 73.30 [2.89] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE 3.51 Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m [.14] 105.65 [4.16] 110.06 [4.33] PART NUMBERS 5.00 5.00 [.20] [.20] 82.16 [3.23] 78.05 [3.07] INSIDE WIDTH 56.90 [2.24] 77.75 [3.06] 56.90 [2.24] 73.30 [2.89] 73.30 [2.89] INSIDE BOX M3-0.5 BRASS INSERTS INSTALLED BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW 1591XXS Enclosure 1591XXSBK 1591XXSGY ACCESSORIES Black Cover Screws [M3-0.5 X10mm] 1591MS100BK (Pkg 100) Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] Black Textured Enclosure Gray Textured Enclosure 4X 3.50 THRU  6.00 X 82° INSIDE LID Dimensions: mm [inches] 1591XXS www.hammondmfg.com ®
1591XXSBK
物料型号:1591XXS系列
器件简介: - Hammond Manufacturing提供的1591XXS系列是一个用于封装电子设备的外壳系列。 - 外壳由FRABS UL 94-V0塑料材料制成,具有阻燃特性。
引脚分配: - 外壳配有4个M3-0.5 X 10mm的机器螺钉,用于固定盖子。 - 内部有4个#4 X 1/4"自攻螺丝(6.4mm)的安装点,用于固定PCB板。
参数特性: - 外壳尺寸:105.65mm x 82.16mm x 56.90mm(长 x 宽 x 高) - 盖子高度:6.50mm - 内部盒子高度:61.90mm - 内部盒子和盖子的PCB安装柱接受#4 X 1/4"自攻螺丝。
功能详解: - 外壳设计用于容纳PCB板,最大尺寸为56.90mm x 105.95mm。 - 外壳可以按需进行工厂改装,如铣削、钻孔、印刷等。 - 推荐扭矩:43-50 Ozf.in / 30-35 cN.m
应用信息: - 适用于需要电子设备封装保护的场合。 - 外壳设计允许用户根据需要进行自定义改装。
封装信息: - 购买的装配包括盒子、盖子、4个盖子螺钉和安装的黄铜嵌件。 - 其他材料/颜色可根据工厂咨询提供。
1591XXSBK 价格&库存
很抱歉,暂时无法提供与“1591XXSBK”相匹配的价格&库存,您可以联系我们找货
1591XXSBK
  • 1+129.714621+16.80258
  • 5+109.050245+14.12582
  • 10+101.2816510+13.11952
  • 25+91.9239525+11.90737
  • 50+85.4607150+11.07015
  • 100+79.48066100+10.29553
  • 250+72.25235250+9.35921
  • 500+71.72322500+9.29067
库存:21
