RH3055
RH3055
    HAMMONDMANUFACTURING
    BOX ABS GRAY 6.3"L X 3.35"W
RH3055 数据手册
160.00 mm [6.30 in] 112.00 mm [4.41 in] 24.30 mm [.96 in] A B B 80.00 mm 85.00 mm [3.15 in] [3.35 in] 79.36 mm [3.12 in] (Inner Base Width) 76.79 mm [3.02 in] (Inner Cover Width) A SECTION A-A 94.09 mm [3.70 in] 151.79 mm [5.98 in] (Inner Cover Length) 80.50 mm [3.17 in] 5.00 mm [.20 in] 72.00 mm [2.83 in] 5.69 mm [.22 in] R.69 mm [.03 in] 30.00 mm [1.18 in] SECTION B-B 95.06 mm [3.74 in] (Inner Base Length) 6.00 mm [.24 in] 78.39 mm [3.09 in] n3.00 mm NOT SUPPLIED INNER PANEL [.12 in] n6.25 mm [.25 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 152.05 mm [5.99 in] 95.53 mm [3.76 in] 77.05 mm [3.03 in] 80.05 mm [3.15 in] n5.00 mm n2.20 mm [.20 in] n6.00 mm [.09 in] [.24 in] BOX - INSIDE 67.00 mm [2.64 in] n6.00 mm [.24 in] PART NUMBERS RH3055 Enclosure Material: ABS (UL94-HB), Light Gray color RH3055 Material: ABS (UL94-HB), Black color RH3051BK ACCESSORIES Lid Screws: M3 x 18 Circuit Board Screws, 4 Supplied (M2.6 self tap) Suggested Lid Screw Torque: 30 ozf-in (21 cN-m) n2.20 mm [.09 in] LID - INSIDE RH3055
RH3055 价格&库存
很抱歉,暂时无法提供与“RH3055”相匹配的价格&库存,您可以联系我们找货
RH3055
  • 1+76.224571+9.53707
  • 5+65.179075+8.15508
  • 10+60.9233610+7.62262
  • 25+55.7143525+6.97087
  • 50+52.0757150+6.51561
  • 100+48.67454100+6.09007
  • 250+44.51570250+5.56972
  • 500+44.00376500+5.50567
库存:1
