RH3155
RH3155
    HAMMONDMANUFACTURING
    BOX ABS GRAY 6.5"L X 3.23"W
RH3155 数据手册
8 7 22.50 mm [0.886 in] A D 6 5 120.00 mm [4.724 in] 3 2 1 26.50 mm [1.043 in] D 27.50 mm B [1.083 in]55.00 mm B 82.00 mm [3.228 in] [2.165 in] 74.00 mm [2.913 in] 32.50 mm [1.280 in] A SECTION A-A ASSEMBLY - TOP C 4 15.00 mm 4X [0.591 in] 152.42 mm [6.001 in] 140.00 mm 2X [5.512 in] 108.00 mm 2X [4.252 in] C 4.25 mm 2X [0.167 in] 5.98 mm 4X [0.236 in] 165.00 mm [6.496 in] 5.00 mm [0.197 in] 32.50 mm [1.280 in] 26.50 mm [1.043 in] SECTION B-B 30.00 mm 2X [1.181 in] R6.00 mm 4X [0.236 in] n3.00 mm 8X [0.118 in] B 2.33 mm [0.092 in] NOT SUPPLIED 80.00 mm [3.150 in] 60.00 mm 2X [2.362 in] 43.00 mm 2X 71.96 mm [1.693 in] [2.833 in] 30.00 mm 4X [1.181 in] INNER PANEL 156.42 mm [6.158 in] B Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. RH3155 Material: ABS (UL94-HB), Light Gray color Lid Screws: M3 x 20 Circuit Board Screws, 4 Supplied (M2.6 self tap) Suggested Lid Screw Torque: 30 ozf-in (21 cN-m) n5.00 mm [0.197 in] n2.20 mm 82.00 mm [3.228 in] 74.00 mm 77.41 mm [2.913 in] [3.048 in] [0.087 in] n8.00 mm [0.315 in] 56.50 mm [2.224 in] A 50.00 mm [1.969 in] LID - INSIDE 2.00 mm [0.079 in] A RH3155 BOX - INSIDE 8 7 6 5 4 3 2 1
RH3155 价格&库存
很抱歉,暂时无法提供与“RH3155”相匹配的价格&库存,您可以联系我们找货
