1553DTBUBK
1553DTBUBK
    HAMMONDMANUFACTURING
    BOX ABS TRN BLUE 5.8"L X 3.5"W
1553DTBUBK 数据手册
Top View of Assembly A SECTION A-A (Side View Inside Assembly) 69.64 [2.742] (Center Inlay Width) Bottom Cover (P.C. Board) Ø 6.00 [.236] (Top and Bottom Assembly Boss Ø) 130.68 [5.145] (Inlay Length) 147.24 [5.797] 5.00 [.197] Top Cover A 58.89 [2.319] (End Inlay Width) 89.00 [3.504] Front Panel SECTION B-B (Inside of Bottom Cover) End View of Assembly B Bottom Cover .50 [.020] Inlay Depth Front Panel 80.95 [3.187] (Inner Box Width At Centre) (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 59.95 [2.360] NOTE 65.95 [2.596] (Inner Box Width At End) Enclosure molded from GP ABS Plastic.  Purchased assembly includes Top, Bottom, front plastic panel and 4 cover screws. (P.C. Board not supplied) Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) B P.C. Board Aligned on PCB Bosses 140.24 [5.521] (Inner Box Width) 77.83 [3.064] Black Enclosure/Grey Over‐mold Grey Enclosure/Grey Over‐mold Translucent Blue Enclosure/ Black Over‐mold Red Enclosure/ Black Over‐mold Yellow Enclosure/ Black Over‐mold Black Enclosure/ Black Over‐mold Front Panel 3.20 X 8 [.126] 10.28 [.405] 5.46 [.215] 41.63 [1.639] PART NUMBER 1553D Regular Enclosure Maximum P.C. Board Size 25.00 [.984] 68.94 [2.714] (Viewing Area) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 3.62 [.143] (PCB dist from inner wall) .46 [.018] (PCB dist from inner wall) 17.75 [.699] (Viewing Area) 4.50 [.177] 19.50 [.768] (Inner Box Height) ACCESSORIES Oval Head Cover Screws Self-Tapping (Pkg 100) [#4 X 3/4" (19mm)] 19.77 [.778] 73.67 [2.900] 22.03 [.867] 46.04 [1.812] 67.32 [2.650] 8.36 [.329] 1553DBK 1553DGY 1553DTBUBK 1553DRDBK 1553DYLBK 1553DBKBK R3.42 [.135] 139.11 [5.477] 62.75 [2.470] 67.83 [2.670] P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] Belt or Pocket Clip 1593QS100 (Silver) 1593QS100BK (Black) 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) 1599CLIP (Black) 1599CLIPGY (Grey) (NOT SUPPLIED) 71.76 [2.825] 30.14 [1.187] 2.50 [.098] 45.89 [1.807] 40.00 [1.575] R4.33 [.170] Dimensions: mm [inches] 1553D www.hammondmfg.com ®
1553DTBUBK 价格&库存
很抱歉,暂时无法提供与“1553DTBUBK”相匹配的价格&库存,您可以联系我们找货
1553DTBUBK
    • 1+166.88356
    • 2+136.70249
    • 4+129.60106
    库存:7
    1553DTBUBK
    • 1+83.21117
    • 2+66.92109
    • 5+63.27977
    库存:7
    1553DTBUBK
    • 1+103.153891+12.33211
    • 5+88.125745+10.53548
    • 10+82.3478410+9.84473
    • 25+75.2955025+9.00162
    • 50+70.3663950+8.41234
    • 100+65.75942100+7.86158
    • 250+61.96382250+7.40781
    库存:168
