1550Z102BK
1550Z102BK
    HAMMONDMANUFACTURING
    BOX ALUM BLACK 3.55"L X 1.43"W
1550Z102BK 数据手册
25.40 [1.00] 90.20 [3.55] 2.50 [.10] (INSIDE DEPTH) A (AVERAGE WALL THICKNESS) 36.20 [1.43] B 29.22 [1.15] B 27.21 (INSIDE WIDTH) [1.07] A 30.40 [1.20] 81.00 [3.19] SECTION A-A END VIEW TOP VIEW 80.59 [3.17] 5.20 [.20] 1.50 [.06] 6.20 [.24] 26.70 [1.05] 4.00 66.82 [2.63] [.16] 26.59 [1.05] 27.00 [1.06] 83.22 [3.28] (INSIDE LENGTH) SECTION B-B SIDE VIEW UL O 12.82 [.50] 81.00 [3.19] C ® US LISTED FILE #E71073 NEMA 4, 4X INSIDE LID Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 84.05 [3.31] 9.80 [.39] NOTE 70.22 [2.76] 15.08 [.59] C 16.22 [.64] Screws should not be torqued past 5-7.5 lbf.in ( 50 -75 cN.m) PART NUMBERS 19.80 30.05 [.78] [1.18] ACCEPTS M4 - 0.7 MACHINE SCREW 2.11 [.08] Purchased assembly includes box, lid, silicone gasket, and 4 cover screws. Box and lid are made from Diecast Aluminum Alloy. ACCEPTS #6 SELF-TAPPING SCREW ACCEPTS #6 SELF TAPPING GROUND SCREW INSIDE BOX C 3.09 [.12] 1550Z102 Enclosure Basic Enclosure Black Enclosure ACCESSORIES Pre-Formed Silicone Gasket NOTE: THIS ENCLOSUE NEEDS TO BE MOUNTED FROM THE BOTTOM SIDE 1550Z102 1550Z102BK 1550Z102GASKET SECTION C-C MOUNTING HOLE Dimensions: mm [inches] ® 1550Z102 www.hammondmfg.com
1550Z102BK 价格&库存
很抱歉,暂时无法提供与“1550Z102BK”相匹配的价格&库存,您可以联系我们找货
1550Z102BK
    • 1+229.90873
    • 2+189.07552
    • 3+179.31106
    库存:55
    1550Z102BK
    • 1+112.32968
    • 2+90.94895
    • 4+85.97808
    库存:55
