1553DRDBKBAT
1553DRDBKBAT
    HAMMONDMANUFACTURING
    BOX ABS RED 5.8"L X 3.5"W
1553DRDBKBAT 数据手册
SECTION A-A (Side View Inside Assembly) Top View of Assembly 69.68 [2.743] (Inlay Width) A 19.50 [.768] (Inner Box Height) Top Cover 4.50 [.177] (P.C. Board) 130.68 [5.145] (Inlay Length) 147.24 [5.797]  6.00 [.236] (Top and Bottom  5.00 Assem Boss ) Bottom Cover A Front Panel [.197] 58.93 [2.320] (Front Inlay Width) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 89.00 [3.504] End View of Assembly B (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) SECTION B-B (Inside of Bottom Cover) .46 [.018] (PCB dist from end panel) NOTE Enclosure molded from GP ABS Plastic.  Purchased assembly includes Top, Bottom, front plastic panel, Battery Door, battery spring clips (4 pcs), 9V adapter (1pcs) and 4 cover screws. (P.C. Board not supplied) Bottom Cover Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) .50 [.02] (Inlay Depth) Front Panel 88.97 [3.503] 59.95 [2.360] B 3.66 [.144] (PCB dist from inner wall) 68.93 [2.714] (Inner Box Width at End) P.C. Board Aligned on PCB Bosses 140.24 [5.521] (Inner Box Length) 25.00 [.984] 80.98 [3.188] (Inner Box Width at Center) 68.94 [2.714] (Viewing Area) 11.49 [.452] 30.14 [1.187] Black Enclosure/Grey Over‐mold Grey Enclosure/Grey Over‐mold Translucent Blue Enclosure/ Black Over‐mold Red Enclosure/ Black Over‐mold Yellow Enclosure/ Black Over‐mold Black Enclosure/ Black Over‐mold 45.89 [1.807] Oval Head Cover Screws Self-Tapping (Pkg 100) [#4 X 3/4" (19mm)] 3.20 P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] [.126] Belt or Pocket Clip 5.46 [.215] R3.42 [.135] 19.77 [.778] 71.76 [2.83] 17.73 [.698] 67.32 [2.650] 46.04 [1.812] (Viewing Area) 1553DBKBAT 1553DGYBAT 1553DTBUBKBAT 1553DRDBKBAT 1553DYLBKBAT 1553DBKBKBAT ACCESSORIES Maximum P.C. Board Size Front Panel PART NUMBER 1553D Battery Enclosure (NOT SUPPLIED) 106.80 [4.205] 62.75 [2.470] 9V Battery Kit AA Battery Clip Kit (4 positive and 4 Negative) 73.67 [2.900] 1593QS100 (Silver) 1593QS100BK (Black) 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) 1599CLIP (Black) 1599CLIPGY (Grey) BS61 1553HDR‐BKIT ® 2.50 [.098] 22.03 [.867] 10.28 [.405] Dimensions: mm [inches] 1553DBAT www.hammondmfg.com
1553DRDBKBAT 价格&库存
很抱歉,暂时无法提供与“1553DRDBKBAT”相匹配的价格&库存,您可以联系我们找货
1553DRDBKBAT
    • 1+123.77887
    • 10+118.83230
    • 20+113.87531
    库存:9
    1553DRDBKBAT
    • 1+126.785141+15.89910
    • 10+107.0510010+13.42440
    • 50+99.2114050+12.44130
    1553DRDBKBAT
    • 1+154.392891+19.36117
    • 5+131.964075+16.54855
    • 10+123.3405310+15.46714
    • 25+112.8057925+14.14607
    • 50+105.4364750+13.22194
    • 100+98.54898100+12.35823
    • 250+97.20763250+12.19003
    库存:2
