1444-10
1444-10
    HAMMONDMANUFACTURING
    Chassis Metal, Aluminum Natural Open End(s) 4.000" L x 8.000" W (101.60mm x 203.20mm) X 2.000" (50.8...
1444-10 数据手册
Bottom View of Assembly A 101.60 [4.00] SECTION A-A End View of Assembly 99.57 [3.92] (Inner Box Width) B B 48.77 [1.92] (Inner Box Height) 2.52 [.10] A 51.82 [2.04] 203.20 [8.00] SECTION B-B Side View of Assembly Bottom View of Chassis (Sold Separately) 2.95 [.12] 201.17 [7.92] (Inner Box Length) 1.02 [.040] 50.80 [2.00] 80.98 [3.19] 182.58 [7.19] 49.78 [1.96] (Chassis Height) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 192.13 [7.56] NOTE All Components Sold Separately Chassis is Made of 0.040" Aluminum. Bottom Plate is Made of 0.040" Aluminum. Bottom Plate (Sold Separately) PART NUMBERS 7.92 [.31] 1444-10 Enclosure Natural Finish Chassis ACCESSORIES Natural Finish Bottom Plate Plated Cover Screws (Pkg 6) [6-32 x 1/4" Self-Tapping Screws] 101.60 4.78 [4.00] [.19] 1.02 [.040] 203.20 [8.00] Dimensions: mm [inches] 1444-10 1444‐10 1434‐10 1421J6
1444-10
物料型号为1444-10,这是一个由Hammond Manufacturing生产的铝制外壳。
器件简介涉及一个铝制底盘和一个单独出售的底盘。
引脚分配信息在文档中未提供。
参数特性包括内盒尺寸为201.17mm(7.92英寸)长,99.57mm(3.92英寸)宽,48.77mm(1.92英寸)高;底盘高度为49.78mm(1.96英寸)。
功能详解指出外壳可以进行工厂修改,如铣削、钻孔、印刷等,并且提供STEP或IGES格式的实体模型。
应用信息表明所有组件均为单独出售,底盘和底板均由0.040英寸厚的铝制成。
封装信息为自然饰面。
有关更多信息,可以联系Hammond Manufacturing。
1444-10 价格&库存
很抱歉,暂时无法提供与“1444-10”相匹配的价格&库存,您可以联系我们找货
  • 1+170.434071+22.09150
  • 10+142.9728310+18.53200
  • 50+132.5985850+17.18730
