1553TTGYBAT
1553TTGYBAT
    HAMMONDMANUFACTURING
    BOX ABS GRAY 6.5"L X 3.15"W
1553TTGYBAT 数据手册
Rear View of Assembly Top View of Assembly 80.00 [3.15] SECTION A-A (Side View of Assembly) 67.31 [2.65] 44.01 [1.73] 28.00 [1.10] (Inlay Width) Removable Panel A (Inlay Width) 33.01 [1.30] 50.95 [2.01] (Inlay Length) (Inlay Length) 5.17 [.20] 2.25 [.09] (Wall Thickness) 165.0 [6.50] Battery Holder 1.50 [.06] (Top Inlay Depth) .50 [.02] (Rear Inlay Depth) 5.00 [.20] 96.31 [3.79] (Inlay Length) 62.45 [2.46] 22.00 [.87] (Inner Box Height) A 31.32 [1.23] 54.11 [2.13] 67.99 [2.68] NOTE Purchased assembly includes Top, Bottom, front plastic panel, Battery Door, battery spring clips (4 pcs), 9V adapter (1pcs) and 6Cover Screws. M3 Brass Inserts are Pre-Installed. Top End View of Assembly 65.00 [2.56] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) Enclosure made from FR ABS (UL 94‐V0) plastic. (Inlay Width) 5.00 Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 7.5 [.30] [.20] 9.0 [.35] 35.00 [1.38] Recommended Cover screw torque -- 2.5 lbf-in (30 cN-m) 18.48 [.73] PART NUMBER 1553TT Battery Enclosure 20.30 [.80] (Viewing Area) 7.5 [.29] 30.00 [1.18] 47.80 [1.88] (Viewing Area) 1553TTBKBAT 1553TTGYBAT ACCESSORIES 21.00 [.83] Front Panel 49.94 [1.97] 22.54 [.89] Black Enclosure/Grey Over‐mold Grey Enclosure/Grey Over‐mold 28.00 [1.10] Cover screw (Pkg 100) [M3-0.5 X 18mm] 8 PCB Posts on Top 45.00 [1.77] 10 PCB Posts on Bottom PCB post accepts #4 X 1/4" self tap screw 28.00 [1.10] Drawings available for maximum P.C Board size. M3 Insert for Cover Screws 2.75 [.11] Inside View of Top Inside View of Bottom Dimensions: mm [inches] P.C. Board Self Tapping Screw [#4 X 1/4" (6.4mm) Plated] Belt or Pocket Clip 9V Battery Kit AA Battery Clip Kit (4 positive and 4 Negative) 1594MS100 (silver) 1594MS100BK (Black) 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) 1599CLIP (Black) 1599CLIPGY (Grey) BS61 1553HDR‐BKIT 1553TTBAT www.hammondmfg.com ®
1553TTGYBAT 价格&库存
很抱歉,暂时无法提供与“1553TTGYBAT”相匹配的价格&库存,您可以联系我们找货
1553TTGYBAT
  • 1+222.158341+27.85909
  • 5+189.950945+23.82022
  • 10+177.5486510+22.26495
  • 25+162.3780925+20.36253
  • 50+151.7689650+19.03212
  • 100+146.34719100+18.35222
库存:2
1553TTGYBAT
  • 1+186.708471+23.41360
  • 10+156.7017510+19.65070
  • 50+146.2489650+18.33990
