1598JSGYPBK
1598JSGYPBK
    HAMMONDMANUFACTURING
    BOX ABS BLK/GRAY 11.03"LX7.85"W
1598JSGYPBK 数据手册
2 Bottom View of Assembly A 1 SECTION A-A (Side View Inside Assembly) Front Face Top Cover 11.42 [.450] (Bottom Boss ) Detail View of Boss  9.26 [.365] (Top Boss ) (Located on Top and Bottom Cover) 3.20 [.126] 280.10 [11.028] B B  8.00 [.315] P.C. Board A 68.00 [2.677] (Inner Box Height) 178.75 [7.037] End View of Assembly B SECTION B-B (Inside of Bottom Cover) Top Cover 2.57 [.101] (PCB dist from inner wall) End Panel 189.64 [7.466] (Inner Box Width) 199.50 [7.854] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Solid models of this enclosure available in STEP or IGES. Contact Factory mjm@hammondmfg.com .50 [.020] (PCB dist from end panel) NOTE Purchased Assembly includes top and bottom cover, front and end aluminum panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4 rubber feet. B 269.60 [10.614] (Inner Box Length) 75.80 [2.984] Front/Rear Panel (Dashed Line Indicates Viewing Area) 15.37 [.605] P.C. Board Aligned on Bosses Maximum P.C. Board Size 128.13 12.33 [5.045] [.486] 9.04 [.356] 185.06 [7.286] (Viewing Area) A 67.00 [2.638] (Viewing Area) 69.50 [2.736] 184.50 [7.264] P.C. Board (Not Supplied) 3.51 X 8 153.75 [6.053] 1598J Instrument Case FLAME RETARDANT ABS (UL94-VO) 1598JBK Bla ck Enclosure w ith Alum inum Pa nels 1598JGY Grey Enclosure w ith Alum inum Pa nels 1598RJBK Black EMI/RFI Shielde d NON-FLAME RETARDANT GPABS (UL94-HB) 1598JSGY Grey Enclosure w ith Alum inum Pa nels 1598JSGYPBK Gre y Enclosure w ith Black Pla stic Pa ne ls ACCESSORIES 1598PLJBK Black Pla stic Pa ne ls 1421T2 Rubber Fee t (Pkg 24) For 1598 FR-ABS 1591MS100 Cover Screws (Pk g 100) [M3 - 0.5 x 10mm] For 1598 GPABS 1591TS100 Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)] For Both Models 1598ATS100 PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)] [.138] 191.30 [7.531] 1.65 [.065] 23.05 [.907] 2 89.00 [3.504] 44.50 [1.752] 268.60 [10.575] 1598J 89.00 [3.504] 1 A
1598JSGYPBK 价格&库存
很抱歉,暂时无法提供与“1598JSGYPBK”相匹配的价格&库存,您可以联系我们找货
1598JSGYPBK
    • 1+167.82940
    库存:13
    1598JSGYPBK
    • 1+227.818861+29.44801
    • 5+191.837365+24.79702
    • 10+178.2710010+23.04342
    • 25+161.8918025+20.92624
    • 50+150.5768750+19.46366
    • 100+140.09778100+18.10913
    • 250+137.62489250+17.78948
    库存:31
