1591XXLFLBK
1591XXLFLBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 3.43"L X 2.28"W
1591XXLFLBK 数据手册
110.79 [4.36] 87.08 [3.43] B 47.42 [1.87] 35.00 [1.38] INSIDE HEIGHT 72.70 [2.86] 43.50 [1.71] A A B TOP VIEW 6.50 [.26] LID HEIGHT 6.10 [.24] 4.34 [.17] 51.65 [2.03] INSIDE WIDTH 2.00 [.08] WALL THICKNESS 57.88 [2.28] 39.00 [1.54] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 36.25 [1.43] BOX HEIGHT 80.00 [3.15] 64.50 [2.54] 51.00 [2.01] 35.50 [1.40] 80.85 [3.18] INSIDE LENGTH 4.50 [.18] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE 4X 3.50 THRU  6.00 X 82° 84.61 [3.33] [.20] 50.20 [1.98] BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW 30.50 [1.20] 51.00 [2.01] 5.00 11.50 [.45] M3-0.5 BRASS INSERTS INSTALLED [.20] NOTE Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS 30.50 [1.20] 1591XXLFL Enclosure Black Textured Enclosure 1591XXLFLBK 36.50 Gray Textured Enclosure 1591XXLFLGY [1.44] ACCESSORIES 3.00 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] [.12] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 80.20 [3.16] 98.30 [3.87] INSIDE LID INSIDE BOX (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 4X 5.00 THRU  9.00 X 82° 50.20 [1.98] 5.00 55.41 [2.18] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. R4.00 [.16] 3.50 [.14] 50.20 [1.98] SECTION A-A SIDE VIEW 30.50 [1.20] Dimensions: mm [inches] 1591XXLFL www.hammondmfg.com ®
1591XXLFLBK 价格&库存
很抱歉,暂时无法提供与“1591XXLFLBK”相匹配的价格&库存,您可以联系我们找货
1591XXLFLBK
  • 1+62.16020
库存:10
1591XXLFLBK
  • 1+85.547631+11.05697
  • 5+71.865975+9.28862
  • 10+66.7263010+8.62432
  • 25+60.5288925+7.82331
  • 50+56.2574750+7.27124
  • 100+52.30616100+6.76053
  • 250+47.53267250+6.14356
  • 500+44.64164500+5.76990
库存:359
