1591XXMFLBK
1591XXMFLBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 3.4"L X 2.25"W
1591XXMFLBK 数据手册
109.96 [4.33] 86.24 [3.40] 72.70 [2.86] 23.00 [.91] INSIDE HEIGHT B 46.58 [1.83] 43.50 [1.71] A A B TOP VIEW 6.50 [.26] LID HEIGHT 25.98 [1.02] 6.11 [.24] 27.00 [1.06] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 4.49 [.18] 80.70 [3.18] 51.51 [2.03] 80.85 [3.18] INSIDE LENGTH 4.50 [.18] 35.51 [1.40] 24.25 [.95] BOX HEIGHT 64.70 [2.55] 50.27 [1.98] 83.77 [3.30] 30.51 [1.20] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE SECTION A-A SIDE VIEW 50.20 [1.98] 51.65 [2.03] INSIDE WIDTH 2.00 [.08] WALL THICKNESS 57.04 [2.25] 4X 3.50 THRU  6.00 X 82° Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. R3.51 [.14] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 3.51 NOTE [.14] 4X 5.00 THRU  9.00 X 82° 50.20 [1.98] Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS 54.57 [2.15] 5.00 [.20] 30.50 [1.20] 50.16 [1.97] 5.00 11.50 [.45] BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW INSIDE BOX M3-0.5 BRASS INSERTS INSTALLED [.20] 30.50 [1.20] 36.00 [1.42] 3.00 [.12] 1591XXMFL Enclosure Black Textured Enclosure 1591XXMFLBK Gray Textured Enclosure 1591XXMFLGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 79.36 [3.12] 98.40 [3.87] INSIDE LID Dimensions: mm [inches] 1591XXMFL www.hammondmfg.com ®
1591XXMFLBK 价格&库存
很抱歉,暂时无法提供与“1591XXMFLBK”相匹配的价格&库存,您可以联系我们找货
