1591XXAFLBK
1591XXAFLBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 3.97"L X 2.02"W
1591XXAFLBK 数据手册
100.90 [3.97] 124.62 [4.91] 21.00 [.83] INSIDE HEIGHT 87.50 [3.44] B 40.94 [1.61] 51.40 [2.02] 2.00 [.08] WALL THICKNESS M3-0.5 X10mm MACHINE SCREW 25.00 [.98] A A B TOP VIEW 38.00 [1.50] 46.15 [1.82] INSIDE WIDTH SECTION B-B END VIEW 6.50 [.26] LID HEIGHT 6.11 [.24] 4.34 [.17] 22.25 [.88] BOX HEIGHT 44.50 30.00 [1.75] [1.18] 95.65 [3.77] INSIDE LENGTH 4.50 [.18] 94.00 [3.70] 80.00 [3.15] 25.00 [.98] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE SECTION A-A SIDE VIEW R4.00 [.16] 65.00 [2.56] 3.50 [.14] 98.43 [3.88] 5.00 48.93 [1.93] [.20] 25.00 [.98] 4X 5.00 THRU  9.00 X 82° 4X 3.50 THRU  6.00 X 82° 44.52 [1.75] 65.00 [2.56] INSIDE BOX M3-0.5 BRASS INSERTS INSTALLED 3.00 30.00 [.12] [1.18] 5.00 11.50 [.45] BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW 94.02 [3.70] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS [.20] 65.00 [2.56] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 25.00 [.98] 113.50 [4.47] INSIDE LID Dimensions: mm [inches] 1591XXAFL Enclosure 1591XXAFLBK Black Textured Enclosure Gray Textured Enclosure 1591XXAFLGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 1591XXAFL www.hammondmfg.com ®
1591XXAFLBK 价格&库存
很抱歉,暂时无法提供与“1591XXAFLBK”相匹配的价格&库存,您可以联系我们找货
1591XXAFLBK
1591XXAFLBK
  • 1+56.91162
库存:4
