1591XXTSBK
1591XXTSBK
    HAMMONDMANUFACTURING
    BOX PLASTIC BLK 4.85"L X 3.28"W
1591XXTSBK 数据手册
123.27 [4.85] B 55.00 [2.17] INSIDE HEIGHT 107.50 [4.23] 67.50 [2.66] A A B TOP VIEW 6.50 [.26] LID HEIGHT 83.27 [3.28] 2.00 [.08] WALL THICKNESS #4 X 1/2" SELF-TAPPING SCREW 59.00 [2.32] SECTION B-B END VIEW 4.34 [.17] 6.11 [.24] 75.65 [2.98] INSIDE WIDTH 115.00 [4.53] 56.25 [2.21] BOX HEIGHT 59.00 [2.32] 4.50 [.18] 115.65 [4.55] INSIDE LENGTH 85.00 [3.35] 119.30 [4.70] 54.50 [2.15] R4.00 [.16] 3.50 [.14] 116.39 [4.58] [.20] [.20] 54.50 [2.15] INSIDE BOX ACCEPT #4 X 1/2" SELF-TAPPING SCREW (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Purchased assembly includes box, lid and Enclosure molded from GPABS Plastic. Other materials / colours available consult factory. Recommended Torque : (35-43) Ozf.in / (25-30) cN.m 1591XXTS Enclosure 1591XXTSBK ACCESSORIES 1591TS100BK (Pkg 100) Black Cover Screws #4 X 1/2" Self-tapping 1591TS100 (Pkg 100) Plated Cover Screws #4 X 1/2" Self-tapping P.C. Board Screws 1593ATS50 (Pkg 50) [#4 x 1/4" self-tapping (6.4mm)] 1593ATS100 (Pkg 100) Black Textured Enclosure 76.39 [3.01] 54.50 [2.15] 85.00 [3.35] BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. PART NUMBERS 5.00 5.00 79.30 [3.12] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE 75.00 [2.95] SECTION A-A SIDE VIEW 85.00 [3.35] 99.00 [3.90] 4X 3.50 THRU  6.00 X 82° INSIDE LID Dimensions: mm [inches] 1591XXTS www.hammondmfg.com ®
1591XXTSBK
1. 物料型号: - 型号:1591XXTS - 黑色纹理封装:1591XXISBK
2. 器件简介: - 该封装是一个金属外壳,具有自攻螺钉,可以安装在PCB上。封装可以进行工厂修改,如铣削、钻孔、打印等。联系邮箱为mjm@hammondmfg.com获取报价。 - 有STEP或IGES格式的实心模型可供使用。
3. 引脚分配: - 封装和盖子上的PCB柱子可以接受#4 X 1/4英寸的自攻螺钉。
4. 参数特性: - 内部尺寸:长度75.00mm(2.95英寸)、宽度83.27mm(3.28英寸)、高度55.00mm(2.17英寸) - 盖子高度:6.50mm(0.26英寸) - 盒子高度:59.00mm(2.32英寸) - 推荐扭矩:35-43 Ozf.in(25-30 cNm)
5. 功能详解: - 封装包括盒子、盖子和由GPABS塑料制成的端盖。 - 其他材料/颜色需咨询工厂。
6. 应用信息: - 最大尺寸的PCB可以安装在盒子或盖子中,但PCB不随封装一起提供。
7. 封装信息: - 封装可以是黑色纹理的,型号为1591XXISBK。
1591XXTSBK 价格&库存
很抱歉,暂时无法提供与“1591XXTSBK”相匹配的价格&库存,您可以联系我们找货
1591XXTSBK
  • 1+101.581951+13.13905
  • 5+85.357495+11.04051
  • 10+79.2751810+10.25380
  • 25+71.9251125+9.30311
  • 50+66.8557450+8.64741
  • 100+62.16895100+8.04120
  • 250+56.50325250+7.30838
  • 500+54.27328500+7.01994
库存:46
